First post, by predator_085
I pulled the trigger for the a ASUS K8V-X mainboard yesterday to have a ultra fast win98 se gaming rig for later games from 99 to 2001.
Is there anything to note when getting a cpu for win98se? I plan to purchaes athlon 64 cpu which ultra fast fo win98se anyway. So the athlon 64 3000plus should be enough or would it be worthwile to consider the 3200, 3400 or even the 3700?
As a gpu I want to get one of he more advanced 9000 series gpu from ati or maybe one of he geforce 5 cards in case in I am lucky. Any objections with that opinion?
And how the the latency bug with sound blaster live cards? is it still a thing with the VIA K8T800 ? or I am fine with getting audigy 2 zs?
Reply 1 of 11, by myne
For the extra few dollars, you might as well get the fastest you can.
There are almost always ways to underclock a fast thing, but no guarantee you can overclock a slow thing.
Plus you get the heat benefits of a newer process.
I assume you know 98 only uses one core. It works with more, but it will never use them. Usually they can be disabled in the bios if you want that nth degree of power saving. If you don't care, it won't matter.
I built:
Reply 2 of 11, by PcBytes
myne wrote on 2025-06-24, 08:49:
For the extra few dollars, you might as well get the fastest you can. There are almost always ways to underclock a fast thing, b […]
K8V is 754 which, afaik, was single core only - the first to get dual was 939.
Reply 3 of 11, by predator_085
thanks for the info. I am ware that win98se only supports single-core cpu.
But it news to me that socket 754 supports a core cpu. The normal Athlon 64 cpus i was refering too aber single-core cpus too.
Edit like @ pcbytes said.
Reply 4 of 11, by shevalier
The most unpleasant thing about such a system is the south bridge, which fundamentally does not work with any SATA2/3 devices.
The choice of SSD will be problematic.
VT8237R - work, but i don`t know any motherboard with it.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 5 of 11, by tehsiggi
shevalier wrote on 2025-06-24, 09:44:
I can just second this. Unless you want to use a plain slow SATA 1 HDD, those SATA ports will be useless. Same story on my MS-7075.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 6 of 11, by shevalier
tehsiggi wrote on 2025-06-24, 09:51:
Seagate SATA2 can be switched with a jumper, IBM - via a utility.
Samsung - don`t know.
This is for HDD of about ~100 GB.
But I have never come across an SSD that could be switched to SATA1 mode.
PS.
GA-K8N51GMF s754
MCP51 from nVidia supports SATA2, but the resulting speed is like SATA1.
And on SATA2 SSD from Intel, SATA 2 did not want to work.
So more or less intelligible SATA2 in those years was only at Intel on ICH7
Reply 7 of 11, by predator_085
Thanks for the warning about potential problems with storage. Good thing that I have not purchased any other parts except the mainboard itself. I wanted to order the extra parts, not before doing some double checking into which problems I could run.
Reply 8 of 11, by shevalier
predator_085 wrote on 2025-06-24, 10:19:
AGP performance 🙁
It seems to be a dependency on the K8T800 revision and BIOS version.
Moreover, the problem is only in Windows 98.
There are several threads about this here.
I have not encountered this, as I use Windows XP.
Reply 10 of 11, by shevalier
Ydee wrote on 2025-06-24, 14:32:
shevalier wrote on 2025-06-24, 10:04:
Some via jumper too, some others via utility https://www.chip.de/downloads/Samsung-ES-Tool_62402659.html
Thanx, BUT...
For building a PC based on the VIA K8T800, I would recommend an IDE to SATA adapter on something like a JMicron.
ATA 100 (or 133?) is not ATA33 (like BX440 or MVP3), it is fast enough.
Some SATA PCI Silicone Image do not provide more speed, but lose in transparency - drivers are needed.
Despite the shortcomings - a great platform.
I always say that "the best BX is Athlon 64 BX"
The only thing better is Turion, but it's hard to get.
Finding a SIS641 motherboard with DDR is borderline possible.
And with P3-S to boot.
S754 is a great and most underrated platform I think.
Reply 11 of 11, by predator_085
@shevalier Thanks for the further details. I will check out the threads you have mentioned to learn more about issues. Sounds like it can be quite ride to make my next project fully functional. I do not mind though. I will be interesting to the all the tinkering.
