Reply 1480 of 1715, by swisstoni
Yes its an ESS 1688 IRQ is 2 DMA is 0 Port is 220 but I cant change the port in ESSCFG is there some way to disable the card in the config? I was previously on an old firmware that didnt have soundblaster support. The games ive bern trying to run are Doom and Duke 3D.
NeoG_ wrote on 2025-06-24, 22:56:I have an ES1869 with a PicoGUS and can run it is SB mode next to the ESS card without lockups - You mentioned the port and IRQ […]
swisstoni wrote on 2025-06-24, 17:27:Thanks for the new firmware update which flashed fine. My system has an ESS1688 integrated on the motherboard ive changed the port and IRQ in software so it doesnt clash with the Picogus.
I have an ES1869 with a PicoGUS and can run it is SB mode next to the ESS card without lockups - You mentioned the port and IRQ but what about the DMA? Can you list what resources each card is set to use?
Was it working with the older firmware, which game is it? I can test it on my system as well
swisstoni wrote on 2025-06-24, 17:27:Also when mounting isos if you have a physical cd drive in your system what drive letter would the iso be?
Drive letters for CD-ROM drives in DOS are controlled by MSCDEX, you supply it multiple /D:<devicename> parameters and they are assigned letters in that order starting with the first free letter. You can also override the drive letter for each drive using /L:<letter> /D:<devicename>
