Because the D6IBA had a few variants, the bios file you used may be the wrong one for a true rev 2.0 board. Are you sure you have a true Rev 2.0 ? Can you take a picture ?
From Soyo USA archive last bios for a Rev 2.0 is "D6IBA-2 BIOS files
bd2-2ca2.bin checksum: 2645 release date: 07/05/2000 BIOS revision: BD2-2CA2
Changes: Fixed the multiplier to 8."
Attached. Note: from Hex Work shop: bd2-2ca2.bin - check sum 16: 2465
added: bios 2AA2 appears to be the first release followed by 2aa3, 2ba1, 2ba2 and last 2ca2...
