First post, by PlaneVuki
Hi !
I have a niche dream of pc:
Covington at 100mhz fsb + S3 pci card + windows 98
But what I discovered is that S3 pci and BX chipset are incompatible.
Gibabyte GA-BX2000 mobo with S3 trio/virge cards freezes randomly on win98.
Siemens Nixdorf D1107 mobo with s3 trio/virge cards freezes after post.
For both mobos other cards isa/agp/pci work just fine.
I could not find much info about this incompatibility on internet, except once somewhere someone mentioned it but I dont remember where.
So I am pretty sure that this isnt just me specific bug.
Have you known about this and is there a fix ?
Are there LX chipsets out there that can go to 100mhz fsb? LX is compatible with S3.
Plz dont question my taste of covington+s3. i know this is not common but i like this niche combo.
Reply 1 of 16, by dominusprog
Are you sure the card is healthy? Besides, why not use an AGP card anyway?
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 16, by PlaneVuki
I habe 4 dfferent s3 pci cards, all work fine on everything else. Fail only with bx chipsets.
Your 2nd question, like i wrote before:
Because its my different kind of dream pc.
Reply 3 of 16, by dominusprog
Put a different card, go into the BIOS and set the 'VGA Boot From' to PCI.
Reply 4 of 16, by devius
You could try a motherboard based on the Via Apollo Pro or ALi ALADDiN Pro II chipset then.
Retro Coisas no YouTube
Reply 5 of 16, by pete8475
PlaneVuki wrote on 2025-06-28, 08:20:
No there are not.
aka pete4237.5
Reply 6 of 16, by Nemo1985
I have hard time to believe that the 440bx is incompatible with s3 trio\virge cards in general and with a quick google search I didn't find any other info and considering how much were common the 440bx boards and the s3 cards it would have been noted before. It could be an issue with the specific motherboard?
Reply 7 of 16, by dionb
My main late DOS machine has an i440BX and an S3 Trio3D card and zero stability issues. I also use S3 Virge cards for testing boards, and my BX boards don't freeze after post with say a Diamond Stealth3D 3000 PCI (Virge/VX) This definitely sounds more specific than "all bx chipsets"
Reply 8 of 16, by pete8475
dionb wrote on 2025-06-28, 17:08:
Yeah this has got me curious, I have several BX boards and a PCI Virge around here somewhere.
I'll dig out the Virge tonight and try it in my CUBX-E and a slot 1 440BX Tyan board I have.
aka pete4237.5
Reply 9 of 16, by AlexZ
Freezing randomly in win 98 could be due to bad driver. Or you could have multiple worn out 440BX boards. I would remove all other cards, disable all ports and internal sound card and use one RAM stick only. Use the slowest CPU you have (ideally a slow Celeron).
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 10 of 16, by dionb
Also: are these the boards you are overclocking that Covington on? In case of any issues, first thing to do is to roll back overclocks.
Reply 11 of 16, by Nemo1985
The most reasonable thing to do would be to try those cards with another bx motherboard but unlucky nowadays they are all except cheap.
Reply 12 of 16, by darry
Hi ! […]
Hi !
I briefly used a PCI S3 Virge 325 on an Abit BX6 V2.0 (440BX ) years ago and it worked fine. It was used with a 300MHz Covington based Celeron.
Reply 13 of 16, by pete8475
Hi ! […]
Hi !
I cobbled together a temporary setup on my messy workbench and it boots right into ME on my Tyan 440BX with a 4MB PCI Virge DX.
Specs:
Tyan 440BX Slot 1 board
Pentium 3 600 (Katmai)
256MB PC100
4MB S3 Virge DX
I just played some i76 (software mode obviously) and some Solitaire but it's booting up and seemingly working fine in anything that I open.
So far that's only Windows itself, Solitaire, i76 and CPU-Z.
I have no idea where my CUBX-E is at the moment so that will have to wait.
Anyway I've attached a photo of the hardware and a couple shots of CPU-Z reporting the board, cpu and graphics.
EDIT - I've also added a pic of the driver details, I'm just using whatever driver ME already had for the card, I haven't downloaded anything.
aka pete4237.5
Reply 14 of 16, by pete8475
I have dug out the CUBX-E and basically done the exact same tests, it runs games in windows just fine with the Virge and took some CPU-Z pics.
I'm sure I have at least one or two other BX boards in storage but I'm not going to get those out just for this.
I also don't remember ever running into S3/440BX compatibility issues back in the day as I ran a Celeron 466 with S3 Trio 3D and Voodoo 2 setup for a while.
At this point PlaneVuki I kind of think you have some defective hardware.
Specs:
Asus CUBX-E
Intel Pentium 3 1.4S (powerleap adapter)
128MB PC133
S3 Virge DX 4MB PCI
aka pete4237.5
Reply 15 of 16, by pete8475
PlaneVuki if you're using the same ram for all of this you should memtest the hell out of it with memtest86. Also look closely to see if there is any damage on your S3 cards.
aka pete4237.5
Reply 16 of 16, by darry
pete8475 wrote on 2025-06-29, 20:04:
This and also making sure that no unintentional PCI bus overclocking is taking place.
As has been mentioned before, testing without any overclocking would be a good test too.
Actually, I would suggest setting everything to conservative values/defaults (clocks for RAM/FSB, memory timings, wait states, etc) and then trying to reproduce the issue and, if still present, running the memtests.
Odd issues like this can be time consuming to narrow down. Best of luck, PlaneVuki .
