Reply 57080 of 58812, by dominusprog
Bought these new old stock CD-ROMs. Unfortunately, I found out the TEAC has the silver panel afterward.
The attachment 20250628_131124.jpg is no longer available
Reply 57081 of 58812, by PcBytes
PD2JK wrote on 2025-06-28, 07:44:
Tnx! Yeah.. DTK, Abit, Epox... All gone... Or merged?
Epox - SuPOX
DFI - gone from retail market, workstation/enterprise only
ABIT - merged with USI, went down in 2009 but the chinese seem to have brought back the universal abit brand back
DTK - unknown
Reply 57082 of 58812, by Repo Man11
dominusprog wrote on 2025-06-28, 10:08:
Now you have an excuse to buy a Lian Li case.
Reply 57083 of 58812, by Masterchief79
Got the ECS Photon KV2 Extreme repaired and cleaned. X2 4800+ was included for pretty cheap, another win in the CPU lottery. 😀
The attachment IMG_20250628_154008878.jpg is no longer available
The attachment IMG_20250628_121602044.jpg is no longer available
The attachment IMG_20250628_124213668.jpg is no longer available
Look at this little disco ball in action.
https://youtu.be/Ms_cMzWX6yY?si=4tA9RevaUXbGtDgw
Reply 57084 of 58812, by Ozzuneoj
Masterchief79 wrote on 2025-06-28, 20:17:
Got the ECS Photon KV2 Extreme repaired and cleaned. X2 4800+ was included for pretty cheap, another win in the CPU lottery. :) […]
Wow, what a crazy board! Lots of questionable early-2000s marketing stuff silk screened on there! Like, what is Dual Channel DDR 999 DIMM? Or PCI Extreme?
All the colorful board lighting is impressive too. This has to be one of the first motherboards with purely cosmetic lighting built in. I have honestly never seen anything like it from that time period.
Such a cool board. And with a 4800+ too! Nice find!
Reply 57085 of 58812, by dominusprog
Repo Man11 wrote on 2025-06-28, 18:39:
That would be ideal for an early 2000 build 😁.
Reply 57086 of 58812, by Masterchief79
Ozzuneoj wrote on 2025-06-28, 20:46:
Wow, what a crazy board! Lots of questionable early-2000s marketing stuff silk screened on there! Like, what is Dual Channel DDR […]
Glad you like It <3
The marketing was wild. They even promoted the rounded corners of the board as a feature and designed a logo for it. 😁
The 4800+ is average at best and tops out at about 2650MHz@1.5V. But no matter.
Last pic with my only purple GFX.
The attachment IMG_20250629_144802413.jpg is no longer available
I also scored a bundle containing a MSI 848P, 3GHz Northwood (30 cap EE reject), 2x1GB Mem, and most importantly, a working Radeon 9800XXL. The CPU had some bent pins, but I got it working again. Tops out at 3.65GHz@1.625V on my ABIT IC7G.
The attachment IMG_20250629_141123356.jpg is no longer available
The attachment IMG_20250629_144852173.jpg is no longer available
The attachment IMG_20250627_143825608.jpg is no longer available
The attachment IMG_20250627_142936073.jpg is no longer available
Reply 57087 of 58812, by justin1985
I always have a soft spot for unusual slim and SFF retro PCs, and when I saw this strange little Fujitsu Siemens "pizza box" when browsing eBay for badly described old PCs, I couldn't resist! Made an offer below the seller's asking price, but probably still paid slightly over the odds for what it is ...
The attachment IMG20250630145720.jpg is no longer available
The attachment IMG20250630145734.jpg is no longer available
It's an i845 based Pentium 4 in a kind-of-ITX type format, but with dual PCI riser card, slim CD-ROM drive, and space + connector for a slim floppy drive (which are available on eBay in the correct Fujitsu off-black with mounting bracket!). This one has a 2.4Ghz Pentium 4 and 512Mb (2 x 256) DDR RAM.
The attachment IMG20250630144825.jpg is no longer available
The PSU is by AC-bel (generally good quality for OEMs?) and seems half way between FlexATX and TFX formats - thankfully it has standard 20pin ATX connector + 4 pin CPU power, and checked out nicely with a PSU tester. I had a moment of thinking it was dead, but realised it will only boot with the "tamper" switch shorted. Remarkably (considering the period and the limited airflow) all the capacitors seem fine!
Any tips for removing the CPU cooler? I tried pushing on the levers, but they seemed very stiff, and I heard some ominous creaks! I'm sure it would benefit from re-pasting, but also sure I've seen horror stories of P4 coolers ripping off the CPU from the socket when removing a dried on cooler?
I'm hoping that the Intel 845G integrated graphics would do the job for most Win9x games, and with an SB-Live or YMF744, this little pizza box would do a good job of retro at my main desk - like a thin client type setup - but with original media drives.
Reply 57088 of 58812, by Ozzuneoj
justin1985 wrote on 2025-06-30, 14:29:
I always have a soft spot for unusual slim and SFF retro PCs, and when I saw this strange little Fujitsu Siemens "pizza box" whe […]
That's a cool little machine! I like the look of it.
Not sure if the PSU could handle it, but it'd be interesting to see how much gaming performance you could squeeze out of it with a PCI video card.
It's been a long time since I've tried to game on first gen Intel Extreme Graphics, but I think the performance is somewhere around a vanilla TNT2 or Rage 128 Pro... but with Intel driver support of course. So, you could drop nearly any PCI Geforce or Radeon in there for a performance boost... it'd just be a matter of when the PCI bandwidth became a limitation. Also, space\heat\power would be a concern. 😀
Or do something crazy and install a PCI HD5450 or GT520\GT610. 😮
Reply 57089 of 58812, by justin1985
Ozzuneoj wrote on 2025-06-30, 15:32:
Thanks! I actually just had a poke around eBay and found an NVIDIA Quadro NVS 280 (i.e. FX5200) PCI for pretty cheap (although I had to order a DBS59 adapter cable too). Cooling is a concern though - with the baffles around the CPU and PSU's surprising lack of grilles other than the fan on the end, there doesn't actually seem to be any actual ventilation of the central part of the PC around the PCI slots ... If I also add a better sound card, it would be very tightly packed, and very little airflow ...
Reply 57090 of 58812, by Kahenraz
The first gen integrated Intel graphics are actually pretty capable, as long as you don't throw anytime too demanding at it. There are drivers for Windows 98 and performance is also very acceptable in DOS. It's highly underrated, although never competitive with whatever was contemporary from NVIDIA or ATI at the time.
Reply 57091 of 58812, by PD2JK
At school we used to play the Soldier of Fortune LAN demo on similar spec machines. From what I remember, it wasn't a slide show. So yeah, great little machine which can handle quite a lot.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 57092 of 58812, by dominusprog
Bought this D-Link USB 2.0 card.
The attachment 20250701_144321.jpg is no longer available
Reply 57093 of 58812, by PD2JK
Nice little card, VIA chip I suppose given the number on the sticker?
Reminds me of sourcing some lower than 50MHz XTALs for the dual Pentium system to do some serious underclocking for passive cooling them.
Reply 57094 of 58812, by gmaverick2k
Yes that's the plan. I'm somewhat obligatory now to find a Chieftec with side window. 😆 […]
gmaverick2k wrote on 2025-06-28, 06:59:
do you have plans to glow it up? I have a lanparty 939 nforce3 ultra but havent done uv lighting before
Ydee wrote on 2025-06-28, 07:20:
file.php?mode=view&id=222627
file.php?mode=view&id=222626
meh, used a lot of uv led strip inside a plastic container for winter retrobrighting my atari st 1040stfm. the plastic had broken so had chucked it all out into garage. just ripped off the led strips (stubbornly stuck onto foil) and tested to see glow effects. it's alright i guess
"What's all this racket going on up here, son? You watchin' yer girl cartoons again?"
Main:z440/2699v3/RTX3060Ti/iFiZenDAC/T480 IPS
98:KT333/AthlonXp 2500+Barton/V3 3000/Vortex2/SC-55
DOS:SS7/P166MMX/V3 2000/PicoGus
XP:Edge72/3570K/GTX970/X-FiTi
Reply 57095 of 58812, by dominusprog
PD2JK wrote on 2025-07-01, 12:37:
Thanks 🙂. I didn't find the exact revision, but it probably is a VIA chip. I hope it works on Windows ME. Yes, I love any card with a big ol' crystal like some revisions of VIBRA16😁.
PS. It seems the chips is a OPTi 82C861, which is great since it works fine on Windows ME.
Reply 57096 of 58812, by bestemor
Masterchief79 wrote on 2025-06-29, 20:12:
Glad you like It <3 The marketing was wild. They even promoted the rounded corners of the board as a feature and designed a logo […]
Glad you like It <3
How did you make that Noctua cooler fit on the 478 socket ??
Which model is it ?
Reply 57097 of 58812, by brostenen
I have not posted in a looooong time. Mostly due to lack of interrest in old school gaming and computing as such...... However.
Sold my Fat Playstation2 with extra's (HDD, network adapter and more), and bought this one (Picture below) for the money I recieved.
The Xbox comes with a modchip, though it working, it really need some love and fixing up.
First the three 3000uF 6,3 Volt cap's at the CPU socket are bulging, but the clock cap have been removed.
The 20gb harddrive are not in the best shape, but I have found a way to clone it on the console it self. I have a 120gb on hand.
Next up, I will be building a controller converter/adaptor, that are multi-console compatible, using a PI-Pico.
(I have also bought a USB converter cable for the OG Xbox)
The attachment xbox.jpg is no longer available
Reply 57098 of 58812, by pete8475
brostenen wrote on 2025-07-01, 22:50:
I have not posted in a looooong time. Mostly due to lack of interrest in old school gaming and computing as such...... However. […]
Have fun!
The original Xbox is great for emulation of a variety of old systems.
aka pete4237.5
Reply 57099 of 58812, by brostenen
pete8475 wrote on 2025-07-01, 23:49:
Have fun!
Thanks.
But the the only reason I bought it for, are to play one title called Outrun2 SP. I have an original, but it plays poorly on my 360. Emulation are done on my Wii anyway. Else I have a Super Nintendo too, but with one of them cartridge that uses SD cards. It is just cool that the Xbox have a bootchip. 😀 Gives me more and better choices, to preserve the HDD.
