Ok, I've got my CD back!  😀
I have heard rumours, that Vista broke some of the low-level CD-ROM features in DOSBox (the ones enabled by the mount -ioctl option). Perhaps burning an image of the CD and use imgmount instead will solve that "File read error"?
Minimax,
You probably have a point there, however I can confirm that the same issue, File read error, also occurs on Win XP Pro SP2. The actual message appears on the DOSBox (0.71) status windows, while the main window (game) shows only a black screen.
I've tried running straight off the CD and mounting an ISO, and both provide the same result. The install routine runs fine, the actual problem is when you execute FIFA96.exe from the CD (did a full install, but the exe isn't installed in C:\FIFA96 , so I have to run it from the CD).
I could, however, use the RIP version and add all the missing contents from the CD (remember doing it in the old days to avoid the cd check) but it would be even better getting the game to run properly...
Just hope it's not the same thing as FIFA Soccer 94, as the only salvation possible for that game was by using a special build made by wd that had "core=prefetch" enabled (that works flawlessly! thanks wd  😉 ).
I'll try some more tests in the meantime, like using the actual label on the iso, trying a bin/cue, maybe running the cd straight from the hd, and so on...
More feedback will be highly appreciated, as this is NOT a specific Vista issue. I'll report back after doing more tests.
