First post, by [FMC]Ravage
So I bought a mobile Athlon XP. It came with installed on a motherboard (AIO I assume) and I can't get the stupid thing out of the socket. There is no lever, just blocks on the end. I assumed they slid outward or side to side...but after prying and beating on it for an hour, I'm at a loss. Has anyone run across these and whats the magic trick to get the CPU out.
Reply 1 of 7, by [FMC]Ravage
Found the manual for it. Their solution was to to use the CPU as a fulcrum to pry against. No thanks. I ripped the socket off the board instead. Hopefully I didn't damage the CPU in the process. I'll see if works on the desktop board tomorrow.
Reply 2 of 7, by PcBytes
For those you usually just use a flathead screwdriver to push in and out of the socket. But I guess ripping works as well? 🤣
Reply 3 of 7, by [FMC]Ravage
🤣 yeah that's what i thought from looking at the arrows/lock printed on it. But I couldn't get it to budge and it was so close to the CPU I didn't want to risk damaging it by prying directly on/towards it (board was just scrap so no loss there). Was this a standard back in the day or was it some abomination HP/Compaq cooked up?
On the flip side, it is kind of scary how easy those sockets come out. I really don't see how a large heatsink doesn't pull it loose over time.
Reply 4 of 7, by Archer57
[FMC]Ravage wrote on 2025-07-09, 14:37:
Was it BGA? I'd expect a through hole socket to be impossible to rip out without ripping out a piece of the board with it.
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 5 of 7, by [FMC]Ravage
No, it was PGA. I'd imagine BGA would be very difficult without a ton of heat on the backside. I was a little annoyed I had to do it that way (its been hard trying to find that particular CPU model).
Looking back, I probably should of taken a break after bending my fingernail backwards and stabbing myself with a flat head screwdriver 🤣
But no bent pins or scratches on the CPU, so we'll call it a success
Edit: I looked at it again just out of curiosity. There is no moving part on the socket. So was the whole socket suppose to slide to release the CPU? But how could it do that if it had adhesive holding it down? Or...are you really suppose to just pry directly on the CPU? Either way....my hate for HP now extends to the early 2000s.
Reply 6 of 7, by Repo Man11
I had a Socket 7 laptop that I upgraded to a K6-2+ decades ago that used this same type of socket. You carefully choose the right size flat blade screwdriver, place the tip in the slot, then rotate the screwdriver about 1/4 turn and it moves the CPU in a lateral direction which releases it from the socket. I've done it about a half dozen times with no issues
Reply 7 of 7, by [FMC]Ravage
So they're not ZIF sockets? You have to use force to insert and remove the CPU? I mean I guess that works but it's not any thinner than a regular socket and you have to pry directly on the CPU.
The CPU works great though. I can change the clockspeed from 400MHz-1800MHz with Setmul (300MHz if I drop the bus down to 100MHz).
