NoCD/NoDVD preservation
First post, by BEEN_Nath_58
As much important it was to preserve old hardware, it was as important to preserve old games. Over time passing, old hardware will just keep getting lesser, which means lesser access to old computers and OS to run old games. Which brings us to new computers to run old games, which will need noCD/noDVDs to run.
One of the largest noCD/noDVD hosting sites was closed a few years back. Other remaining ones can get nuked one day or another. Has anyone taken the effort to preserve these modified binaries?
Reply 1 of 10, by keropi
if you search on archive.org there is a 50.8gb archive from 2013
but other than that I know nothing else that exists
Reply 2 of 10, by eM-!3
Out of curiosity I've checked one of the oldest sites that I remember and yes, GCW is still there.
Reply 3 of 10, by chinny22
eM-!3 wrote on 2025-07-09, 12:00:
Phew even back in the late 90's early 2000's that was my first port of call.
I've always NO-CD my games to help preserve them. So for any game I own I generally have a zip containing the iso, any patch and associated no-cd crack.
Reply 4 of 10, by crusher
keropi wrote on 2025-07-09, 06:56:
Sounds interesting!
Can you give hints for the search terms?
//EDIT:
I found it 😀
Reply 5 of 10, by DosFreak
They already did.
The problem with sites like that is that for the most part these are modified copyrighted binaries instead of patches or diffs so would be copyright infringement. The DMCA allows bypassing when it no longer effectively controls or protects (when the company no longer supports so it cannot be ran but it also applies when the company supposedly still supports it but doesn't fix it so it can be ran....see court cases for precedent) but copyright infringement is another matter so only a patch (best option) or diff (since only a 'part' of the work is being copied) are legally allowed and yes you actually do own the software no matter what a EULA or T.O.S states since you bought it. Obviously this doesn't mean you can do whatever you want with it but you are legally allowed to keep it and get it working to run it no matter what you hear elsewhere. (Talk to a lawyer to confirm). The above applies to the U.S.A.
Make your games work offline
Reply 6 of 10, by The Serpent Rider
I think SafeDisk, Starforce, TAGES SolidShield and now SecuROM fall into "no longer controls or protects" category. Many SecuROM protected games (especially old ones) already acted very finicky on Windows 10 and Windows 11 just killed all support. So end of support for Windows 10 marks the end of all major disc DRMs legally.
Reply 7 of 10, by BEEN_Nath_58
The Serpent Rider wrote on 2025-07-10, 10:10:
There was some work done on SafeDisk emulation by RibShark. I think the oldest games can work with it, however it didn't work on SafeDisk v1 for me
Warez releases sites still hold them, however its quite an hassle to get each game and extract the crack out of it
Reply 8 of 10, by The Serpent Rider
BEEN_Nath_58 wrote on 2025-07-10, 12:43:
Not a user problem at this point anyway. Easier to apply old cracks.
Reply 9 of 10, by old school gamer man
know its not the most convenient workaround but if you install demon tools and use it s command line commands to make a ,bat script that auto mounts a disk image, runs the game/app then dismounts the image after the app/game closes
