Since it is from 1988, I strongly suspect that this card doesn't have VGA hardware on it. I don't see a VGA rom on there. It's probably an add-on accelerator board that expects to connect to a VGA card in a different slot using a VESA feature connector, just like the first generation of 8514a compatibles, TI 340x0 cards, or the Matrox ISA cards.
The earliest card with both VGA & 2d acceleration features that I know of was the original ATI Graphics Ultra ( EXMCOMBOVM ) from March 1991.
Edits
Here is a reference to a $2850 Verticom M-16 & M-256 Graphics cards in 1985 -- https://books.google.com/books?id=_y4EAAAAMBA … 20M-256&f=false
^^ Z80a and MC68000 coprocessors
Here is a reference to a$2399 Verticom "2Page" graphics card / monitor from 1988: https://archive.org/details/pcworld65unse/pag … =verticom+2page
^^ Used an intel 82786 graphics coprocessor
Here is a reference to a $1 ,695 Verticom MX 16/ AT and the $2,095 Verticom MX 256 / AT https://archive.org/details/PC-Mag-1989-01-31 … /2up?q=verticom
^^ Had onboard VGA, used a TI 34010 graphics coprocessor
I couldn't see an verticom boards in the infoworld graphics roundup from 1990 -- https://books.google.com/books?id=KjwEAAAAMBAJ&pg=PA59
Looks like Verticom may have been absorbed into Western Digital by that point
Here is a reference to the "Verticom HX16AT, HX256AT, HX256MC" from 1989: https://archive.org/details/byte-magazine-198 … /2up?q=verticom
https://www.ardent-tool.com/video/8514A_Stand … o_Wants_It.html
"For instance, Verticom has let it be known that while its initial hardware offerings will use the 34010, the company will be offering a higher performance version of its boards, which it will call the HX series. The HX series will incorporate the AI but will use proprietary VLSI—not a reverse-engineered 8514/A chip set — to carry out 8514/A functions. Verticom will supply drivers for Windows and several other programs written directly to this hardware, but will rely on both its AI implementation and its special chips to increase performance of other software applications written to the AI."
So seems like your board is most likely a "Verticom HX256/AT". Can't find a photo though. Looks like it came out right on the cusp of the Paradise acquisition, which complicates things.
https://www.vgamuseum.info/images/doc/wd/corp … w_fall_1988.pdf
