First post, by Unregistered
with running dosdrv...
how can i input the -goobers and the -debugmode of this games...
how?
how?
Make a batch file that runs the game with the command-line parameters and have VDMSound run the batch file instead of the EXE file.
More details pls...
I'm not too technical about this...
sorry man...
Use Notepad or any similar text program to create a text file. In that file, type in:
Wolf3d.exe -goobers
or
Wolf3d.exe -debugmode
Then save it with an easy-to-remember name like GOOBERS or DEBUG. Quit Notepad (or whatever program you used). Then rename the last 3 characters of that text file from .TXT to .BAT. Then drag that file into your Wolf3D directory.
That is your batch file. You then run it with VDMSound just like any .EXE file.
Also try NewWolf. It's great. 😀
wrote:Also try NewWolf. It's great. 😀
URL? 😜
