First post, by luRaichu
I bought this SATA+IDE controller card for my Biostar MB-8500TTD which has the 430TX chipset. It's PCI 2.1 only and the VT6421A uses PCI 2.2 according to its datasheet.
The BIOS detects it as a "Mass storage device" on IRQ 11, but it will not boot from an IDE CD-ROM drive attached to the card.
I tried to flash the Memphis ROM to it with the provided DOS program but it couldn't detect the ROM chip type...
Then I plugged the card into a newer ATX PC running Linux and it showed up as a RAID controller. I could mount attached SATA drives. But when I tried to read or write the card's ROM with flashrom it kept saying it couldn't find a compatible PCI device even though the card ID from lspci matches up with other cards that others flashed successfully.
I'm pretty sure the EEPROM chip is real? Some of these cards are sold with a fake ROM covered by a sticker.
Reply 2 of 12, by bertrammatrix
luRaichu wrote on 2025-05-27, 18:02:
I bought this SATA+IDE controller card for my Biostar MB-8500TTD which has the 430TX chipset. It's PCI 2.1 only and the VT6421A […]
It is normal for them to not be able to boot from CD, and also for the CD rom to not be detected under DOS. Not 100% sure about that card in particular, but my promise IDE cards are like that.
If I use them usually I just leave a cable attached to one of the motherboards ide plugs and use that for windows installation/ any dos benchmarks etc I may want to run from a CD. I suppose a more elegant approach could be just having a second drive for this purpose but meh
Reply 3 of 12, by jakethompson1
XCDROM and the other ATAPI CDROM drivers in FreeDOS can sometimes find PATA/SATA CDROM drives on nonstandard I/O ports by looking through PCI configuration space for them
Reply 4 of 12, by luRaichu
Here is what my card looks like.
Reply 5 of 12, by Wurenji
luRaichu wrote on 2025-05-27, 23:42:
I bought the same card last week, to use it as a programmer to flash a bricked Socket 754 mainboard. At the beginning I had same problems.
First, you need a 32-bit Linux installation to let Flashrom recognize this card. I tried on Debian 11 amd64 on a Gigabyte 8I865GME-775-RH with ICH5 southbridge, this card showed up in lspci but same "can't find a compatible PCI device" error. Then I tried it on a G41 mobo with ICH7 southbridge and Debian 11 i686, the error changed to "no supported EEPROM was found". I switched to verbose mode, now the card is properly detected by Flashrom.
Second, you need to remove two resistors (R39 and R40, located near the lower-left of the ROM chip) to get the ROM detected. R37 to R40 determine the address of corresponding ROM chips to let up to 16 chips connected to the same LPC bus. As we only have one chip it should be 0000 (R39 and R40 populated = pulled high = 1100). After that, the ROM get recognized.
Third, this particular model of ROM (SST49LF004B) is not supported by Flashrom with atavia programmer. I replaced it with a SST49LF040 and it worked. You can modify the source to add support for 004B, but it might not work as it's a FWH mode chip (a variant of LPC by Intel) instead of "pure" LPC like the 040.
PC#1: Ryzen 7 3700X / MSI X470 GAMING PLUS MAX / RX 9070 XT
PC#2: Core i9 13900H / Lenovo ThinkBook 16p Gen4 / RTX 4060 Laptop
PC#3: Xeon E3 1230 v2 / Gigabyte Z77M-D3H / GTX 760
PC#4: Pentium E5800 / Gigabyte 8I865GME-775-RH / X800 XT AGP / Audigy 2 ZS
Reply 6 of 12, by luRaichu
Thank you for this information.
I removed R39 and R40, but the WR6421 program for DOS says that the LPC flash VID/DID (Vendor ID/Device ID) is FFh/FFh and it's Unknown. That's probably the same error I was getting earlier.
Also, this card uses the same EEPROM as mine. https://theretroweb.com/expansioncards/s/gemb … to-sata-and-ide
Reply 7 of 12, by luRaichu
I ran flashrom from i686 Debian 11 Live but it still isn't finding my card. Maybe it can't access the PCI bus? This is on a Dell Inspiron 530 which has an Intel G33 chipset.
The attachment P5190658.JPG is no longer available
The attachment P5190659.JPG is no longer available
I will try replacing the ROM with an SST49LF040
Reply 8 of 12, by luRaichu
My SST49LF040 arrived and I installed it on the VT6421A, but no luck flashing it on Linux or DOS. I may have done some Bad Things while soldering.
Next, I tried to add the (64K) Memphis ROM to my Award BIOS using CBROM. But it seems there is no room for it (only 32K free). Is there a way to squeeze it in?
If not, I must use an option ROM on an Ethernet NIC to boot. I have a Macronix MX98715 based card, it's a clone of the DEC "Tulip" chip. I don't own an EEPROM programmer so I would rather use this card to program the option ROM. There is a patch for flashrom on Linux to read/write ROMs on DEC Tulip cards.
Reply 9 of 12, by pc2005
luRaichu wrote on 2025-05-28, 16:31:
edit: oh no I misread the device number, sorry
SST49LF004B should be fine as it supports both LPC and FWH (with autodetection). Unless it is re-labeled fake. Mine card has a paralel (!) flash with dodgy marking 😁.
Do you have any other LPC flash chips to test? (ideally with a plcc socket)
luRaichu wrote on 2025-05-29, 20:33:
Can you run
lspci -nn
So we can see VID:DID numbers? If lspci sees the card, flashrom should too (LPC flash access is same register access as lspci loading info from). However it seems flashrom supports only DID == 0x3249 as it seems from the source code, so we need to be sure.
atavia also sometimes requires an
offset
argument as specified here.
Reply 10 of 12, by pc2005
Did you have a luck with your VIA card?
I finally bought PM49FL002 for my card and it works halfway. I can flash it in the card and I can read out the image correctly (using flashrom in linux), but the image doesn't show up in PCI option ROM BAR. There is some weird incompatibility with PM49FL002 flash or my via chip's option ROM doesn't work at all.
My card didn't have pullup on TBL# pin, so the boot block in flash was locked against writing.
Also I wonder how the VT6421A does the LPC address decoding as it would need to know where the flash starts (256kB would start at `0xFFFC_0000`, 512kB would start at `0xFFF8_0000`) as the optionROM image is stored from the start. A nonzero ID settings can only shift the start of the flash to the lower address. The VT6421A seems to only support up to 64kB optionROM window so only `0xffff_0000` could be accessible. I tried to pad the RAID bios to 64kB and repeat it to get the final image for the flashrom, but it didn't work anyway 😒
Reply 11 of 12, by luRaichu
pc2005 wrote on 2026-04-19, 00:34:
No, as it happens it wasn't compatible with my board. According to datasheets that VIA chip seems to use PCI features that are too new for the 430TX chipset.
I tried the Memphis ROM on a NIC but it would not run. So the ROM isn't compatible either.
I got a Sil3114 card instead and after changing the EEPROM it flashed and worked fine in that PC.
Reply 12 of 12, by pc2005
It should work on 430TX. But if you have a replacement working I guess it doesn't matter anyway.
