Dead MS6166 - Now fixed!
Reply 20 of 29, by paradigital
CC-Adam wrote on 2025-07-09, 18:30:
Nice! Well done, plus you have given me motivation to dig mine out again soon maybe they're just really fussy with regards to CPU. Hope you get the drive sorted 🤞
What OS are you planning for this build?
Thanks. Fingers crossed for yours also.
This is likely going to be 98Se, though possibly (and sadistically) maybe ME. I’d have used both OSes on my Compaq back in the day.
Reply 21 of 29, by CC-Adam
Thanks I'd pretty much written it off but it was showing similar signs of life as yours! 🤣
Dare I say it I am actually quite a fan of ME now I use it quite regularly on a Tualatin machine (with a similarly basic board with no AGP slot 🤣). It runs really well on there for some reason, blisteringly fast. 95 is my favourite OS but ME is easier sometimes, mainly as USB flash drives behave out of the box I think!
Reply 22 of 29, by paradigital
Had to give up on an SSD. Tried three SSDs from 64GB to 128GB, all of them hang on IDE auto detect.
First SATA HDD (160GB) I tried works fine. Would rather avoid spinning rust, but at least it works, though limited to 8GB.
Reply 23 of 29, by kotel
That's a bit odd how these boards would only like 450mHz chips. Maybe the BIOS doesn't support CPUs above 45omHz? Gotta try an 700mHz p3 on my MSI boards and see if they do the same.
Always has the weirdest issues happen, and always is all alone with them
Reply 24 of 29, by paradigital
kotel wrote on 2025-07-10, 08:01:
I don’t see how that would be possible so long as the microcode is the same (i.e. same CPU architecture/stepping).
Unfortunately I only have the three Katmai PIII CPUs. And no Klamath/Deschutes at all, so can’t really test further.
I guess I could try my Coppermines in the board, but I don’t want to build a fast Slot 1 machine, I’ve already got two of those (Tualatin 1.4 in a Powerleap IP3-t in an ASUS P2B-F, and a 1GHz Coppermine in an ABIT BE6-II).
Reply 25 of 29, by kotel
Just for testing you could try the coppermine. Not sure if 440bx even supports Tualatins (not talking about the pinout).
Reply 26 of 29, by paradigital
Well, it’s installed and working, but the video performance seems a bit lacklustre.
CPU, memory and disk performance all seem perfectly acceptable for the hardware, but the video performance is terrible.
I’ve installed the GOTY release of Half-Life and whilst it’s too old to support the net_graph command, I don’t need an FPS counter to know that the performance is abysmal.
In direct3d and OpenGL it would appear you are talking in frames per minute rather than frames per second. Software rendering is fine, even up to 1024x768.
I don’t remember the Rage 128 VR being this slow, certainly it was a 3D accelerator not a decelerator like some other cards (cough S3, cough).
I could only find a single driver that actually installed, so I don’t really have any options there, but I seem to recall back in the day that there were ATI minigl drivers? Or am I misremembering that?
Reply 28 of 29, by Roman555
paradigital wrote on 2025-07-10, 06:14:
The BIOS Patcher may fix the 8GB limit. You have a programmer TL866ii so why not to give it a try:
https://www.vogonsdrivers.com/getfile.php?fil … 241&menustate=0
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 29 of 29, by paradigital
Roman555 wrote on 2025-07-19, 17:40:
Thank you, I’ll give it a go.
In other news, I gave up on trying to get the Rage 128 to be anything other than a boat anchor, so I’m now using a Radeon 7000 PCI, which seems to give period correct framerates for most titles I’ve tried.
