Random CRC errors on larger files [solved]
First post, by schlang
Hello, I copy files from my Windows 10 main computer via network to my Windows 98 installation.
Edit: this also happens in DOS.
However random files come with CRC errors, it can't be reproduced if I copy the same files again the error happens on other files.
Most files are multi-part 50MB chunks so I'm wondering there is something I need to turn on in the Win98 network settings or is there a magic size my chunks need to be?
Thank you.
Edit:
I installed USB in Win98 and when I copy large files from the SD card I have the same issue, getting CRC errors when extracting the files.
Looks like a file transfer issue in general, what could it be?
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 2 of 32, by schlang
I tried but unfortunately didn't fix it.
Reply 3 of 32, by schlang
I could reproduce the issue in DOS, can we close/delete this thread and I will create a new one with more infos in the appropriate forum?
Reply 4 of 32, by y2k se
Run a memory test on the system.
Tualatin Pentium III-S 1.4, ASUS TUSL2-C, 512MB RAM, GeForce 4 Ti 4200, Voodoo2, SB Live!, 3Com 3C905C, 80GB IDE HDD, Dell 2001FP
P233MMX, Intel LT430TX, 64MB RAM, Sierra Screamin' 3D, Voodoo2, AWE64 Gold, 3Com 3C905B, 40GB IDE HDD, Viewsonic A75f
Reply 5 of 32, by schlang
Any program/distri you can recommend? I remember I never had any errors with memtest even after 24 hours
Reply 6 of 32, by Shagittarius
This sounds exactly like failing memory. I had this same issue.
Reply 7 of 32, by y2k se
schlang wrote on 2025-07-14, 14:04:
I used some older version of MemTest86+ on my retro machines to test memory I bought on eBay.
Reply 8 of 32, by bertrammatrix
schlang wrote on 2025-07-06, 23:36:
Slow down memory and/or cache and see if the errors stop
Reply 9 of 32, by schlang
I used BIOS failsafe defaults but with the same result.
Now I'm running memtest86, should I be using memtest86+?
Reply 10 of 32, by schlang
Thats what I have after 2 hours of memtest
Reply 11 of 32, by y2k se
That appears to confirm bad RAM, or RAM being run past it's specs.
Reply 12 of 32, by schlang
I made further tests and the CRC errors do not happen if I disable both Internal and External CPU Cache in BIOS
Reply 13 of 32, by darry
schlang wrote on 2025-07-14, 22:56:
And what happens if you disable one OR the other and test ?
Reply 14 of 32, by schlang
I tried first with only external cache disabled and I had CRC errors. Do you suggest it would make sense to try internal disabled and external enabled?
Reply 15 of 32, by schlang
Memtest86 throws errors on test #5 with cache enabled, looks very reproducable
The attachment memtest2.png is no longer available
Reply 16 of 32, by darry
schlang wrote on 2025-07-15, 10:23:
If you can reproduce the issue with only one of the caches disabled, it would strongly suggest that the fault lies with that cache.
Keep in mind that the K6-iii+ has on-board L1 and L2 cache AND yout motherboard's installed L2 cache, if any, effectively becomes L3 cache, AFAICR.
I don' have any personal experience with that CPU, but I suspect that your BIOS option for L2 cache actually enables/disables only the motherboard cache while BIOS option for L1 cache actually enables/disables BOTH the L1 AND L2 on-CPU caches. This can probably be validated through the CTCM cache check utility and/or K6-3 specific utilities.
That being said, if the system used to run reliably and now doesn't, it suggests a hardware fault with either the CPU itself, the motherboard cache or the motherboard itself being the most likely culprits (in descending order), IMHO. The PSU, in this case, seems like an unlikely candidate, but stranger things have happened.
Another thing look into is whether any specific BIOS settings might be required for this setup to run reliably might no longer be set due to a CMOS clear. I am just speculating on this one.
Reply 17 of 32, by konc
Also it was correctly suggested earlier to relax the cache timing but there was no feedback on this, or whether such BIOS options exist at all.
Reply 18 of 32, by schlang
I use BIOS Fail Safe defaults, no aggressive timings.
I switched out the mainboard and the errors are gone, I assume we can rule out CPU and memory which leaves the board as the culprit.
Is it time to throw the board away or can it be salvaged?
Reply 19 of 32, by weedeewee
schlang wrote on 2025-07-15, 13:35:
Has the board ever had its capacitors replaced ?
Do not ask Why !
