Reply 57180 of 59379, by PD2JK
A VRM for the Kayak came in today, works like a charm.
The attachment DSC_5078.JPG is no longer available
The attachment DSC_5079.JPG is no longer available
The one thing left to do, is fixing that cracked little LCD ont the front. I sourced the spare part for 25 USD, but the shipping is 100 USD! Not going to spend that...
has all kinds of stuff
Reply 57181 of 59379, by PcBytes
CharlieFoxtrot wrote on 2025-07-15, 17:38:
PcBytes wrote on 2025-07-15, 17:24:
CharlieFoxtrot wrote on 2025-07-15, 15:26:
That sounds like something that could be relatively easily repairable, though. Cracked solder joint on the chip legs or some components.
I've resoldered all SMDs that are between those ICs. Same behaviour.
Damn. Have you checked it under the microscope if there is some cracked SMD cap or resistor there besides reflowing the solder joints? It may be difficult to see those with a naked eye. It definitely sounds like there is a contact issue of some sort that prevents it from powering on.
I swapped all SMDs from another P3B with a snapped socket. Same behaviour. All SMDs are fine, checked under microscope as well.
Reply 57182 of 59379, by Kahenraz
It could be a hairline crack on a PCB trace.
Reply 57183 of 59379, by PcBytes
Kahenraz wrote on 2025-07-15, 23:03:
Tinned all traces I could find to eliminate that possibility. Still the same outcome.
Reply 57184 of 59379, by Halofiber86
justin1985 wrote on 2025-07-11, 21:15:
Correct! It's not as dramatic as the sliding cover on the towers, but it's great to see IBM went to the trouble of fitting a damping mechanism - press the dimple and it very gently rolls open.
Thank you very much for going through the trouble, sir! Good luck with your gem!
Reply 57185 of 59379, by myne
Most likely the chipset bga balls.
Since it should be leaded solder a good flux, preheater, and hot air station might do the trick.
Obviously a reflow isn't as good as fresh solder but the degree of difficulty between a reflow and reball is too high for most casual solderers.
I built:
Reply 57186 of 59379, by CharlieFoxtrot
myne wrote on 2025-07-16, 04:39:
Agree, that is probably the only possible issue left if all the surface solder joints are pretty much now checked. Reflow is definitely worth the shot.
Reply 57187 of 59379, by asdf53
Would you apply flux around the edges of the chip and blow it underneath with the hot air gun as it liquifies?
Reply 57188 of 59379, by pete8475
Insomnia and ebay are a dangerous mix.
I just ordered an ASRock 775i65PE motherboard and 2 SL9KE 3.4GHZ P4 processors. I'm hoping one of the two will be stable at ~4.5 or so.
I really need to stay off ebay at 3:00AM. 🤣
aka pete4237.5
Reply 57189 of 59379, by PD2JK
Haha yeah, and when you wake up "oh no what did I do". I had a few moments of those...
Reply 57190 of 59379, by Lutsoad
I auto-transfer a set amount to my virtual wallet each month and that's my retro budget. I can spend it all in one month or save it up to buy something big but never exceed that amount. Once it's gone I'm off the shops until my next paycheck. I had to make that rule after I spent $500 on various e-junk in a matter of weeks but didn't really need any of it. 😁
Now I only buy things I really want.
Reply 57191 of 59379, by myne
asdf53 wrote on 2025-07-16, 07:39:
Yeah. But you won't have to blow it. Surface tension and capillary action will work their magic.
Recommend low/no clean flux
I built:
Reply 57192 of 59379, by PcBytes
Thanks! I got it to work with a mild 365*C reflow on the southbridge. No preheating as I don't have one nor the means to get/DIY one.
Reply 57193 of 59379, by asdf53
myne wrote on 2025-07-16, 12:10:
Nice, I've been wanting to do this for a while now with two boards that keep crashing during hard disk transfers.
PcBytes wrote on 2025-07-16, 12:58:
That's awesome! If you only have a heatgun, you can also preheat with that. I use it with a large nozzle to preheat the board to 120C before soldering difficult joints or large SMD parts, works great.
Reply 57194 of 59379, by PcBytes
asdf53 wrote on 2025-07-16, 14:13:
In my case all it took was aluminium foil and flux to do it. I didn't really see the need to preheat and there wasn't any popping during the procedure.
EDIT: And another success - a pretty corroded TNT2 Ultra from @Socket3 is now living again, thanks to the same technique.
Reply 57195 of 59379, by myne
Nice! All good now?
Pre heating is recommended because spot heat can warp a board pretty severely. I tried to replace an lga socket once without one and the board bowed easily 3cm
I built:
Reply 57196 of 59379, by PcBytes
myne wrote on 2025-07-16, 17:05:
Nice! All good now?
Yeah, all is working now. Tested IDE ports as well to make sure they both register, and they do. Will install 98 or 2k with a GF256 and see what scores do I get 🤣.
I didn't get any warping. Not sure but maybe the nozzle size helped?
Reply 57197 of 59379, by Mandrew
Bought this because I like shiny golden things. 😁
Reply 57198 of 59379, by Repo Man11
pete8475 wrote on 2025-07-16, 07:44:
The Onion had a story years ago: Man With Complete Mama's Family Video Library Never Going On eBay Drunk Again
"NEWTON, MA—In a solemn pledge to himself and the world, Kevin Wollersheim, the new owner of a complete Mama’s Family video library, announced Monday that he will “never, ever again” shop the online auction house eBay while inebriated.
https://theonion.com/man-with-complete-mamas- … oin-1819565279/
Reply 57199 of 59379, by pete8475
Repo Man11 wrote on 2025-07-17, 01:57:
The Onion had a story years ago: Man With Complete Mama's Family Video Library Never Going On eBay Drunk Again […]
Tremendous! 😁
aka pete4237.5
