First post, by NemessiS82
Hi, I'm emulating Paratrooper in Dosbox, and when I set the controls to joystick, the firing barrel automatically moves to the right. Every time I correct it, it returns to that position. I think it's because I can't calibrate the joystick, since the game doesn't give you that option. I'm using the Dosbox cores in Retroarch, but the same thing happens in all of them. Any solution? Thanks.
Reply 1 of 1, by Stick
I've never used Retroarch, but if you can change DOSBox settings in it, see if it helps to change joystick to timed=false.
