First post, by xtreger
I have an Audigy 2 ZS - in a few use cases, it starts behaving abnormally after a bit of usage.
Behavior: The sound (e.g. game sound or music recording in DAW, etc.) will cut off abruptly, then there will be a static like noise, the very end of the windows 98 startup sound will play randomly, and the normal sound (what should've been playing under normal circumstances) will cut in and out (mostly out).
Examples:
1. In the game Hitman Contracts if any level of sound hardware acceleration is enabled, the sound will play just fine for, say 20 seconds. But after a point the above behavior will start - a trigger point that I've noticed is when I go to an area where multiple sound effects from different sources are supposed to be playing at once. Like rain sound, NPC dialog, truck sound, etc. all at once.
2. In a DAW when recording instrument via a USB instrument cable, it records fine for max 2 minutes, after which that abrupt sound cutoff and noise behavior will start again.
3. While playing DOOM, only after a few seconds of gameplay with both MIDI music and game effects playing, this same behavior starts.
I'm really at my wits' end on what to do about this. I've tried both VxD and WDM drivers, I've tried Joseph Joestar's guide, the unofficial VOGONS drivers - every combination seems to give this issue. If anyone has had the same problem or knows why this happens, would really appreciate any help or pointers.
