Reply 240 of 293, by Deunan
dennisE wrote on 2025-07-13, 12:05:How do I check the voltage at pin 24 of the HD146818? I understand that I connect pin 24 on one side of the tester, and the other side (battery or power supply)?
You need to measure between pin 24 and GND (ground plane). For GND you can pick pin 12 (opposite corner of 24) or perhaps one of the black wires in any spare PSU connectors. Using the pins directly will give you more accurate result but with decent PSU wires even using a plug far away from the chip the difference shouldn't be more than 0.1V anyway.
dennisE wrote on 2025-07-13, 12:05:If I put in an external battery, for example, 3.6V, will it be enough to work?
It should be enough, but some older mobos required 6V external pack, and had more than 1 diode that caused voltage drop. These are rare though. The 3xAA pack will give you 4.5V which is a perfect value, high enough to ensure good chip power supply, low enough to not be drained if the mobo has just 1 diode (unlike 6V pack would be). Cheap, comes with wires, preferably look for one that already has the pin-compatible connectors.
Note you can't just connect a battery in place of the original rechargeable NiCD without modding the power supply path there. If you just do a 1:1 swap the mobo will force current through the new battery, trying to recharge it, and it will eventually cause the battery to fail - bloat and/or leak. That's another reason why I don't like doing CR2032 mods to these old mobos, it's not as simple as it looks.
