First post, by renejr902
Hi guys !
1. I have a early 386 dx 16 mhz cpu and motherboard. I'm triying to identify the board online, thanks. I cant find it yet. It seems one of the first motherboard with a 386 cpu on it. For now it doesnt boot, but it has some leaked varta battery damage, i will repair it later. If you find any info on it let me know, thanks.
https://postimg.cc/gallery/RwxhVw1
2. Can this 386 dx 16 motherboard be use with a standard AT psu ? the power pins looks a little different and it miss one pin vs standard AT connector.
3. I have too a 386 dx 20 cpu and motherboard that boot very well. The model is ECS 386/32, you can find it easily online. But i think it uses standard 386 edo ram memory, but with pins soldered on contact. I have a lot of standard 1mb 386 ram. Can i solder pins on my memory to put on this computer to get 8 mb or at least 4 mb. Is it possible to solder pin at these 386 ram stick ?
Thanks a lot for help and answers.
