First post, by PixelPolish
We've got FreeDOS which can be installed on modern hardware and run DOS games and apps, but supposedly you can't install Win 98 on top of it, only Win 3.x
At least that's how far searching the internet got me. I have found an ancient thread about installing Win98SE on modern-ish hardrware, but not sure if that's still applicable, are there any new creative ways, etc.
Old thread: How to install Windows 98SE on a modern PC
Thanks in advance. I can't find any 1997-ish laptops in working condition that do not cost both of my kidneys, so I would settle for my old lappy that is too slow to be used in any other way and it just seems such a shame.
Years later and I'm still on the lookout for my nostalgic Ergo Computing CD-NoteBrick (pic below), but it doesn't seem like any are surfacing anywhere. Would love to get my hands on a 95-98' IBM or even Toshiba laptop, but the prices are a little too crazy for my budged. Eh...
The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man.
~George Bernard Shaw
My YouTube Channel
Reply 1 of 9, by crusher
What about a VM?
Reply 2 of 9, by DarthSun
Win98 can be installed natively on a modern machine, but some conditions are required: NVidia 7xxx, Radeon X8xx or older video card is required.
You also need a Win98 compatible sound card.
FreeDOS is not required, it has its own DOS (DOS7.1).
You also need:
Loew mem-driver, if the system RAM is larger than 512MB
Loew TBPLUS driver
Loew SATA(AHCI) driver
The installation is quite complicated and may vary from machine to machine.
It also runs on Ryzen, for example:
The attachment 225621_maf0o3fhf4kjimhx_70328_2000_98.jpg is no longer available
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 3 of 9, by DaveDDS
PixelPolish wrote on 2025-07-17, 10:13:
We've got FreeDOS which can be installed on modern hardware and run DOS games and apps, but supposedly you can't install Win 98 on top of it ...
Unlike MS/PC/DR etc... FreeDos is still a developed thing, much more likely to support modern hardware...
.. and unlike 3.1, 95/98 is more tied into DOS not just running on top of it ... so I wouldn't expect it to
work on non-MS/IBM
I have DOS/Win3/Win95/98/Nt/2K/XP/7 and a few flavours of Linux running (quite well) on my (not terribly recent by
todays standards) I7 desktops and laptops ... under "VMware Player 7" - this is a virtual machine under Windows which
was free... intended to be able to run VM images created by the (paid for) "Vmware Workstation"
But for at least a little while VMware released versions of "Player" which allowed you to boot Floppies/CDs and do
OS installs - not sure it still allows this now.
You could also look at "VirtualBox" another (and fully free) VM.
I chose VMware because at the time I was working for a client who was using it for other
reasons (I had the .vmdk on a removable hard drive which I could easily take with me between
their and my offices)
I kept the "Player7" install, disconnect from Internet when I install it (otherwise it will update before installing)
- and never let Winblows "update" it... Still works well for me.
A couple advantages of doing it this way...
1) You can easily backup/restore the full machine (.vmdk disk image - I always tell it to store the disk image
in a single file) - super handy when you want to "try" some package and have the option to easily restore the
system to "it was never there"
2) Dead easy to copy a VM to another system. (Like a laptop so you can travel with it)
Player will notice this and an ask "Did you copy or move" - ALWAYS say "move" - otherwise
it will change the virtual hardware (NIC address etc.) enough that some OSs will think they
have been "pirated" .. just take care not to run multiple instances of a copied VM at the
same time.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 4 of 9, by wierd_w
Unfortunately, I dont see a readily available way to combine both csmwrap and memdisk, on a Grub2 boot option line.
CSMWrap is a WIP UEFI executable based generic CSM for use on EFI only systems.
New project called CSMWrap, a new legacy OS boot solution for UEFI-only systems lacking a built-in CSM
https://github.com/FlyGoat/CSMWrap/wiki/Usage-Guide
Memdisk is part of the IsoLinux toolset, and creates a bootable ramdisk, using a physical HDD disk image or floppy diskette image file. It needs a CSM to be present.
https://wiki.syslinux.org/wiki/index.php?title=MEMDISK
Maybe someday CSMWrap will permit passing a linux kernel and initrd line to it. When/if that ever happens, it could be used with Memdisk to boot a legacy OS on modern iron in a safe and convenient way that is GPT partition table friendly.
But again, sadly that does not seem to be the case.
But until then, it can be used to boot from a storage device that has a properly set up MBR partition table, and bootable partition, on EFI only systems.
Reply 5 of 9, by UCyborg
DaveDDS wrote on 2025-07-20, 02:12:
Newer VMware Player versions can create virtual machines, there's just not as much knobs to be playing with.
VMware Workstation Pro became freeware in May 2024, so VMware Player was discontinued in its favor, account registration at Broadcom is required to be able to download from official source.
The biggest thing with newer versions are less restrictions applicable to serious server environments, newer Direct3D support for Windows guests, possibly better compatibility with newer versions of host OS. At least with VirtualBox I played with couple of years ago (which is forever in computer world!), its drivers were most surely to work right with period correct Windows version.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 6 of 9, by chinny22
My main concern with a laptop is you can't change the video or sound card.
That old thread you linked specifically has a section on this at the end explaining you may need to find compatible cards for a computer.
Not saying you shouldn't get a laptop and downgrade, just double triple check if sound/video in Win9x will work
Reply 7 of 9, by DarthSun
chinny22 wrote on 2025-07-20, 23:35:
I also have an older laptop - Athlon-II-X2/HD4250/integrated sound. DOS/XP can run on it without any problems, but Win98 is not good because there is no video/sound driver. The latter is better solved on a desktop computer, or a laptop natively with all components compatible with Win9x.
Reply 8 of 9, by Malik
Depends on what is meant by "modern systems".
AFAIK, there are 3 methods :
1.For running Win9x natively :
A Socket 775 based Pentium 4 desktop system can be considered a modern system if talking about Win9x compatibility, which is the last generation that can run Windows 98SE/ME natively.
A Win9x native laptop, like the Thinkpad T42 is a mobile alternative that can run Win9x natively since drivers exist even now.
2. Running Win9x with hacks :
Get a Windows 9x supported last gen Nvidia or Radeon cards - e.g. - Nvidia 6800 Ultra or Radeon 9800XT, or even X800 or X850XT (yes, Win9x drivers exists for these cards) along with a Win9x supported SoundBlaster card - e.g. Audigy or Live! 5.1 cards and install them on newer post-Socket 775 motherboards with PCI-E slots. Though, AGP slots are preferred. Some motherboard drivers won't be available for Windows 9x, but the main thing - graphics and sounds work. Which are the most important for running Win9x based software. Also, use PATCHMEM - https://archive.org/details/PATCHMEM if having more than 512MB RAM in the system, otherwise Win9x won't boot after install.
3. Running Win9x under a virtual machine
I'm also running Windows 98SE "natively" in my Debian system using QEMU. Runs fully 3D accelerated games using Softgpu - https://github.com/JHRobotics/softgpu.
Reply 9 of 9, by SquallStrife
Check out the YouTube channel Omores, for some wild shoehorning of old Windowses into new hardware.
The recurring theme is that it isn't straightforward, and probably isn't worth the effort for anything other than the adventure of setting it up.
