Reply 20 of 29, by assortedkingdede
- Newbie
chinny22 wrote on 2025-07-04, 05:22:Nice and simple IDE hard drive, that's good as it means we can rule out issues caused by adapters! :) […]
assortedkingdede wrote on 2025-07-04, 02:39:chinny22 wrote on 2025-07-04, 02:15:What motherboard and hard drive are you using? How did you partition the hard drive? […]
How did you partition the hard drive?Only time I've had similar issues was using adapters and partitions weren't aligned properly.
but are many other causesMy motherboard is a Asus CUSL2 rev 1.2. My hard drive is a Seagate ST3120025ACE that is 120 gb.
Nice and simple IDE hard drive, that's good as it means we can rule out issues caused by adapters! 😀
I'd run Seagate tools to check the drive health.
https://www.seagate.com/au/en/support/downloa … -legacy-supportHow was the hard drive partitioned? Personally I only use fdisk it's not as fancy as 3rd party tools but you it'll setup the drive in a way compatible to windows
With 120GB you'll need the updated version
https://archive.org/details/windows-98-and-se … drive-fixes.-7zIs this just a standard install of Windows or are you using something like the unofficial service pack or similar?
I ran some checks with seatools and the program did not seem to find anything unusual. Strangely, I am starting to notice a pattern of the faliure going back to the system files, one case Windows.com failed and currently, there is an issue with the registry that Windows was "unable to fix". I have also noticed my primary partition seems to have resized itself to be twice as big (likely partitioning mistake on my end setting up with fdisk).
