First post, by Sphere478
- l33t++
At long last,
It looks like I have finally found a (working/usable) tillamook 4.5x for my socket 7 collection. And it comes in a package I had previously never heard of. (see also Pentium 1 366mhz The Infamous Golden Tiger/Warrior)
The following is a information and image dump of what I know so far. Info/pics Provided by Batyra.
And this is what ChatGPT found after deep search on archival japan forums. So the same as I did.
HP5-MX300-L – Multiplier Switch (SW1) and FSB Settings
CPU Multiplier Configuration via SW1 (DIP switch)
The Buffalo HP5-MX300-L is a CPU upgrade module featuring a mobile Intel Pentium MMX 300 MHz processor, designed for Socket 5/7 motherboards. On the PCB, there's a set of four DIP switches (labeled SW1) used to configure how the CPU runs .
The first three switches (SW1-1, SW1-2, SW1-3) control the CPU multiplier, adjusting how the CPU clock relates to the base FSB frequency . The factory-default configuration is OFF, ON, OFF, OFF (in order) —this sets the module to the highest supported multiplier.
By changing SW1-1 to SW1-3, you can select lower multipliers (useful for alternate CPUs or lower FSB boards). The available multipliers range from around 1.5× up to a maximum of 4.5× .
The fourth switch (SW1-4) does not affect the multiplier—it likely has a different function (not clearly documented in sources) and is usually left in its default position .
Multiplier Limits and FSB Dependency
SW1 settings allow for a maximum multiplier of 4.5×, which results in ~300 MHz when used with a standard 66 MHz FSB . Higher multipliers (e.g., 5×) are not supported—Japanese sources confirmed no DIP combination results in more than 4.5× .
This limitation affects users installing the module on boards with lower FSB. For example, in a PC-98 system with a 60 MHz bus, the max achievable clock would be 270 MHz (60 × 4.5) .
The multiplier is set entirely by hardware (via the SW1 DIP switch) and doesn't rely on BIOS support. This enables the module to function even in systems that don't officially support MMX CPUs.
NOTE: Some systems may require additional software or settings to support the MMX write-back cache mode, but that is unrelated to the multiplier itself.
