feipoa wrote on 2025-07-17, 02:40:
My interposers all had i486DX4-100 WT chips on them. They work fine with Cx5x86 and Am5x86 CPUs. If you can find some from China, they are usually very cheap. I sent my contact a message of inquiry about more.
So far, my contact has not replied, but he read the message. Either he is still trying to find the interposers, or he isn't interested. Will wait another week, then message him once more.
douglar wrote on 2025-07-23, 01:31:
Message me if you hear back. Sounds like an Evergreen Technologies 586 AMD 5X86 upgrade chip could work as well, yes? I imagine you use a hot air station to remove the original chip?
I doubt those would work, for 2 reasons.
1) most of those Evergreen interposers contain a 1117 VRM, which normally maxes out at 800 mA (some brands note 1 A). According to the IBM 5x86C 3.3V Microprocessor QFP Addendum (Fax #40045), at 100 MHz the minimum current draw is 0.8 A, and max is 1.1 A. How much does the Cx5x86 draw at 150 MHz and, say, 3.7 V? Probably over 1.5 A.
2) those Evergreen interposers have the VRM set to 3.45 V. You would need to modify the interposer with a trimmer to go over 3.45 V. I have done this on one of my Evergreen modules, as well as swapped the VRM for a beefier unit (maybe 3 A). Howvever, there were several revisions of the Evergreen Am5x86 interposer and not all of them have the solder pads for the larger VRM.
