Reply 29900 of 31937, by dominusprog
- Oldbie
brostenen wrote on 2025-07-20, 22:45:When I look at the reaction, the powder that are used, have a really large surface. And the thinner the super glue is, the faste […]
dominusprog wrote on 2025-07-20, 19:05:brostenen wrote on 2025-07-20, 12:28:Promised some pictures, but they where lost. So I made 6 new ones. Posting in a new reply. […]
As you can see. I have used super glue and baking powder as well as cotton on various sollutions.
As I did not use any drill or power tools for this job. All cut out with a sharp knife, and holes where made using a screw and screwdriver.
I reused as many used parts as possible. And I crafted new stuff from what is essentially trash.
The goal was to create something, in the lines of what was done in computing hobby back in the 1970's.
Basically get a naked computer, and build a case around it. I just used modern tech by using an Orange PI.
I hope it is npot overbuild, in regards to electrical safety.Forgot that I can only add 5 pictures. But the front panel only contains one flip-switch that I took from the main power switch, from an ATX PSU.
It is a 240 volt switch, and are connected between the Live wire and the power socket. Lots of shrink wrap to insulate. 😜A few years ago, I bought this glue called "welding glue", which was a tube of super glue and a box of black powder. I don't know what it was, but it has a same effect as baking soda. Anyway, good job on the power supply, these DIY projects are gold 🙂.
When I look at the reaction, the powder that are used, have a really large surface. And the thinner the super glue is, the faster it dries and get hard.
Are cinnamon not more fine in grain size than baking powder by the way?Anyway. I actually managed to produce smoke from the use of cotton. I have no idea if that is too dangerous.
Also, the fumes hurt the mucous membranes in the nose and makes the eyes burn.
So getting too close are not adviceable at all.The dark or black powder in that kit you wrote about, might be powdered graphite. I might look for some of it and give it a test. Or perhaps toner from laserprinter.
And thanks regarding the PSU. I have no idea if it is safe enough, with my job on the 240v line. If insulation are good enough or something.
I just used my knowledge from electrician ground school about safety, and increased insulation and that stuff. Even modern PSU's with that switch, leaves the leads unshielded inside.
So I hope it is safer than generic factory made, CE labeled stuff.
I guess getting shock by live wire is part of the job 😅. Last year repairing a dryer, and it has a broken solder joint and piece of a plastic (for holding the heater in place), so I grab the heater thinking I was unplugged it and got zapped 😁. And that was one of many incidents 😅.
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
