Reply 40 of 45, by Vany
Archer57 wrote on 2025-07-24, 04:09:Do not underestimate the effectiveness of this heatpipe + fin stack + fast radial fan design. Small as that fin stack is such co […]
Vany wrote on 2025-07-24, 03:35:Problem is that just the radeon gpu has this problem with overheating. Either way, this might sound dumb and insane but I've decided to create a custom cooling solution for this thing that must fit in the original case. Plan is to cannibalize a low profile gpu's heatsink, and solder a dedicated usb fan directly to one of the usb ports. Whenever I get the parts to do so, I'll post the photos here.
Now that I re-read this, how stupid it all sounds, saving a mid-range laptop from 2008 for no reason at all... hah
Do not underestimate the effectiveness of this heatpipe + fin stack + fast radial fan design. Small as that fin stack is such cooling solution is used everywhere for a reason - when everything works properly it can dissipate a lot of heat.
Do not expect simple heatsink fitted within the same space to be more effective.
Also strange that only GPU has issues. Being connected with a heatpipe temperatures should not be dramatically different. This points towards heat pipe not working properly or contact issues even more.
And it is not stupid at all, as long as it is fun - why not fool around with old hardware?
If it was cooling max. 2 chips, then maybe but in this case, it simply isn't enough. A toshiba that I used to have with an i5-4200M and a GeForce 710M would heat up to 92C and that had two copper pipes which were thicker and a better fan. I understand if the CPU is an ULV model or the gpu is weak then yes a single pipe will be "adequate", but in this case, remember, 3 power hungry chips are being cooled by it. The Toshiba with an i5 at least had a sticker that the laptop will get very hot though. Also, after some more searching, I find this to be a common problem with T500s equipped with a 3650 or a FireGL chip... What makes this worse is that all 3 chips are continuously powered and generate heat even when idling. I only have the option to disable the Radeon in the BIOS which doesn't help.
Anyway, the custom heatsink will be an aluminum slab cannibalized from a low profile gpu, I'll cut it and attach a USB fan to cool the slab, therefore the chip also. I often find IBM laptops at a flea market so if I find a similar model, I might swap the cooling system so I can properly check if this one is truly done for.
