Reply 40 of 43, by myne
Actually, I made one possibly wrong assumption there: the filedate would be circa 199x/200x, but on mine I'm seeing 202x
Gotta go out though
I built:
Reply 41 of 43, by myne
Here.
Copy all the update exes into a folder
Copy this to the folder
Run - preferably from the powershell commandline
Output should be 3 files
files.bat
cats.bat
regs.reg
I believe this should simply keep working even if you keep piling more updates in there.
Just make sure they're not major upgrades like dx9 - or test them separately and combine
I used the following ME updates for dev:
I built:
Reply 42 of 43, by myne
You'll have to check the output manually.
I noticed some files being copied to blank because the destination folder appears to be a custom folder number pulled from the registry based on the install path.
Quite clever, but would have to be fixed manually
I built:
Reply 43 of 43, by myne
Comments added into reg/bat to make it easier to see where things go wrong.
I built:
