First post, by Mourales
Hello everyone! (I'm new in this forum),
I'm having trouble configuring the IDE channel on an old 486DX, where both the hard drive and the CD-ROM drive are connected. However, the floppy drive or Gotek work perfectly.
The issue is that, although both are recognized, they don't work.
This makes it impossible to work properly. I've tried several hard drives and CD-ROM drives, and also swapped the IDE cables, but the result is always the same.
So it's either a configuration issue or the IDE controller is failing.
Any help someone can offer would be greatly appreciated.
Thank you very much in advance.
