EAX appreciation thread
Reply 600 of 1253, by sharangad
UCyborg wrote on 2025-07-28, 18:23:
sharangad wrote on 2025-07-23, 11:54:
Meanwhile here's Drakan:
https://youtu.be/K0eKUydsugw
Inside the church uses auditorium preset, the entry part uses cave preset. Level Editor says EAX volumes are set to low levels, so I guess it's correct that they sound subtle / quiet, which was my initial observation in other areas of first level.
The church does sound different and there's no reverb outdoors.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 601 of 1253, by UCyborg
Just in case it wasn't clear, first part inside the church uses cave preset, the one before the main area. The main area uses auditorium.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 602 of 1253, by sharangad
UCyborg wrote on 2025-07-28, 20:09:
Ah ok.
Reply 603 of 1253, by Joseph_Joestar
sharangad wrote on 2025-07-28, 16:25:
Unreal was the very first game that ever supported EAX, according to Creative's old website.
On that note, I used the OldUnreal update on a newer PC a few years back, and was amazed by how well it utilized OpenAL to faithfully reproduce the EAX features of the original version. Kudos to the OldUnreal devs on that!
My retro stuff
Reply 604 of 1253, by sharangad
Joseph_Joestar wrote on 2025-07-29, 07:15:
I was looking at their site early while looking for the 225f patch. Didn't realise it was a port.
Reply 605 of 1253, by AndreaColombo86
Hello, everyone! It’s good to find a thread where people understand that audio in games is a big deal ☺️ I really miss EAX and CMSS-3D.
This coming weekend I’ll put together my first retro machine with a Sound Blaster Live! 5.1. The sound card choice is deliberate, cause I wanted a WinXP machine but my priority are the Baldur’s Gate games and I wanted the occlusion effect (which, through the BGT mod, will apply to the first game as well.)
However I already have an upgrade planned for October—can’t afford it before then—which includes a Titanium Fatal1ty. I’ll swap the two sound cards depending on the games I want to play.
Couple questions for the savvy in this thread:
- What are the best drivers to use under Windows XP 32bit for the Fatal1ty?
- Do the GOG versions of Quake 4 and F.E.A.R. support EAX or was it stripped? I’m not above fetching the games on disc if need be.
Reply 606 of 1253, by sharangad
AndreaColombo86 wrote on 2025-07-30, 18:49:
Gog quake 4 has eax.
Reply 607 of 1253, by Joseph_Joestar
You can either use the original installation CD or follow my guide. Avoid the latest official drivers from Creative since they can cause bugs with games that use OpenAL.
I have both games on GOG and they do support EAX. However, I think F.E.A.R. was recently added to their "preservation program" so I'm not sure if the current version can be installed on anything older than Win10. I downloaded the GOG offline installer years ago, so my copy still runs fine on WinXP.
My retro stuff
Reply 608 of 1253, by AndreaColombo86
Couple more questions from me: would an Auzentech X-Fi Forte 7.1 be better than an X-Fi Titanium Fatal1ty?
Would the same drivers work for the Auzentech?
Reply 609 of 1253, by Joseph_Joestar
AndreaColombo86 wrote on 2025-08-01, 12:59:
It's a higher grade product with superior build quality, so it will give you cleaner sound. In terms of EAX capabilities, it uses the same CA20K2 chip as the Titanium Fatal1ty. Meaning, it supports EAX 5.0 and every version below that.
No idea. Maybe someone who has that card can chime in.
My retro stuff
Reply 610 of 1253, by AndreaColombo86
Ah, looks like the one on eBay comes without the metal bracket at the back of the card, so I wouldn’t be able to mount it. Pity.
Reply 611 of 1253, by old school gamer man
Joseph_Joestar wrote on 2025-08-01, 13:33:
It's a higher grade product with superior build quality, so it will give you cleaner sound. In terms of EAX capabilities, it use […]
I had one of those, wile the hardware is goodish far better then a stock X-Fi the drivers are 100% crap, you can't use the stock drivers with it and dan k drivers don't work right with it in XP and the drivers from Auzentech I was able to find are super buggy and glitchy. Its a shame too as they are rather nice hardware. If you want better sound get a DAC for you X-Fi Titanium Fatal1ty.
Reply 612 of 1253, by AndreaColombo86
Wouldn’t a DAC defeat the purpose of having the X-Fi?
I could, on the other hand, get a mini jack to RCA cable and hook my headphone amplifier to the X-Fi—but only if the output volume of the X-Fi proves insufficient.
Reply 613 of 1253, by old school gamer man
AndreaColombo86 wrote on 2025-08-01, 14:47:
no. it just replaces the analog output on the card and not the card, you would still have EAX and be able to use the control panel apps with the card
Reply 614 of 1253, by AndreaColombo86
How would you connect the sound card to the DAC? SPDIF?
Reply 616 of 1253, by AndreaColombo86
Just checked, it’s an optical SPDIF. Awesome, I should be able to use it with my DAC. I’ll try that for sure, thanks for the head’s up!
Reply 619 of 1253, by AndreaColombo86
Has anyone tried this with Diablo II? Does it work / does it sound good?
https://forum.median-xl.com/viewtopic.php?t=59898
EDIT: is it even needed when playing on WinXP with a Sound Blaster?
