First post, by AndreaColombo86
Hello, everyone.
I’ve been reading a bit about getting SATA to work on Windows XP, but one thing is unclear.
If I set the BIOS to IDE mode for compatibility, then install Windows XP normally, then install SATA drivers after the fact—can I then safely switch my BIOS to SATA/AHCI mode?
I don’t have a floppy disk drive on which to put the drivers.
