Reply 29920 of 30668, by Linoleum
I picked up this 1995 CD-ROM drive for just a few bucks, and honestly, it's the cleanest and best looking drive I've ever seen—even compared to models from the 2000s! But it came with one issue: the tray motor was completely seized. So I gave it a little spa treatment—soaked it in WD-40, gently rotated the motor with some pliers, cleared out the WD-40 using compressed air, and added a touch of fresh oil. Now it's running like new, back to its glory days!
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge DX, SB32, PicoGus
486DX4 100, CL-GD5424, SB32, SC55
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA Basic, Forte16
Reply 29921 of 30668, by Ozzuneoj
Linoleum wrote on 2025-07-28, 23:26:
Wow, that's a good match for that computer with the darker colored button and volume dial.
Nice job!
Reply 29922 of 30668, by Linoleum
Ozzuneoj wrote on 2025-07-29, 00:03:
Nice job!
Thanks! I thought I would be the only one noticing the color matched buttons... 🤣!
Reply 29923 of 30668, by Ozzuneoj
Just testing out some video cards here and I came across something odd.
I have an XFX AGP card that is labeled as "Geforce4 MX440SE 64MB SDR TV-Out VGA". The system detects it as an MX440 (not unusual), but Everest says that is, get this: using SDR running at 333Mhz?
RivaTuner says the card is a 128bit MX440 with SDR Memory. The memory clock (on the info page) is shown as "166.5Mhz (MPLL doubling detected)"; Memory PLL FVCO is 333.0Mhz. SIV shows that the memory clock is 333Mhz.
The memory chips are V-Data VDS6616A4A-6, so they are 6ns SDRAM (166Mhz). The datasheet is available here.
Obviously the chips can't lie... they don't seem to be DDR memory, and they are only rated at 166Mhz. But it is odd that more than one program is detecting the memory clock as 333Mhz. Maybe it's just because the MX440\440SE are supposed to use DDR (often 64bit...), so these programs just assume the speed should be doubled?
Reply 29924 of 30668, by vutt
Day 1 of my AWE64 memory upgrade adventure. SMD soldering baby, yeah!
Tomorrow I need to program and solder GAL chip in order to get rid those botch wires. Also "beutify" PCB - remove flux and perhaps give some touches to my amateurish soldering...
...and donate this guy for his effort: https://bitsundbolts.com/2025/07/01/the-small … xpansion-board/
Reply 29925 of 30668, by T-Squared
Somehow I got Cosmo's Cosmic Adventure working on a V20 processor last night, which, according to the game's documentation, should be impossible.
Reply 29926 of 30668, by Ozzuneoj
T-Squared wrote on 2025-07-30, 19:58:
I had to look up that PC you're using (I see you made a thread about it a few months back), because I have never seen a PC like that with a tiny color CRT. I thought any machines that came with built in screen like that were monochrome. Very cool system!
Reply 29927 of 30668, by pan069
vutt wrote on 2025-07-30, 19:24:
It's an interesting project. A couple of years ago I managed to buy these boards (image below) from "the bay". I think they were produced by a Russian seller. It might be sanctions related that I haven't seen these being sold since.
The attachment PXL_20220304_231828798.jpg is no longer available
Reply 29928 of 30668, by DarthSun
Speaking of Awe expansion, I bought SimmConn 7 years ago.
The attachment 1AweG1.jpg is no longer available
The attachment 1AweG2.jpg is no longer available
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 29929 of 30668, by dionb
Bought a PC based on potatocam photo that looked like it had a nice EISA motherboard but was filthy and damaged
Then picked it up:
- no damage, little filth
- case is a very nice AT bigtower from the early 1990s
- nice EISA+VLB motherboard (TMC PET48PN)
- decent VLB VGA and I/O cards, MS bus mouse card and 3.5" and 5.25" HD FDDs
Also pile of RAM in the board, looks like 8x 4MB 30p SIMMs and 2x 8MB 72p SIMMs so 48MB on an early 486. Impressive.
But...
Hooked up the motherboard, attached a PSU, VGA and POST card and:
00
C1
** BLAM **
Tantalum cap exploded on me. The board is riddled with them. Need to replace a lot and just hope nothing else was damaged when it blew. Probably also need to perform surgery on the DS1387 RTC+SRAM chip, but at least it's socketed.
Reply 29930 of 30668, by T-Squared
Ozzuneoj wrote on 2025-07-30, 20:41:
It's about to be expanded more, since I recently got a Xircom PE2-10BT parallel ethernet adaptor!
There seems to be a problem with the CRT circuitry, because the colors don't seem to contrast well enough. I don't care if they don't match up exactly with CGA/EGA specification, I'm more worried about the fact that the dark colors look nearly the same as the light colors.
Reply 29931 of 30668, by dominusprog
DarthSun wrote on 2025-07-30, 21:04:
Is this an original part?
Reply 29933 of 30668, by dominusprog
pan069 wrote on 2025-07-31, 21:16:
Nah, it's an aftermarket product but no longer produced. Similar models are now produced by Serdashop. […]
dominusprog wrote on 2025-07-31, 12:03:
https://web.archive.org/web/20190306030347/ht … onn.tripod.com/
https://www.serdashop.com/SIMMCONN
Thanks for the info.
Reply 29934 of 30668, by DarthSun
[/quote]
That it wasn't a factory item, it was designed by a small manufactory, and it was available to order for a while. They asked in a domestic topic if I needed it, because group orders are available.
It works fine, even though it was turned on a long time ago.
The attachment 1Awe_GUS_1.jpg is no longer available
The attachment 1Awe_GUS_2.jpg is no longer available
The attachment 1Awe_GUS_3_1.jpg is no longer available
Reply 29935 of 30668, by PcBytes
Upgraded a 128MB GF6600 to 256MB, using a donor card - both are PNY, both use the same RAM.
Reply 29936 of 30668, by dominusprog
DarthSun wrote on 2025-07-31, 21:57:
[/quote]
Got it 🙂. Nice build by the way, I'm currently working on my SS7 and I just bought a case similar to yours, post a pic of the front if you can.
Reply 29937 of 30668, by dominusprog
Just watched the review of Earthion on Game Sack. The great Yuzo Koshiro is back with a bang!
https://www.youtube.com/watch?v=EMDz0wxj2qM
Reply 29938 of 30668, by DarthSun
dominusprog wrote on 2025-08-01, 04:26:
That it wasn't a factory item, it was designed by a small manufactory, and it was available to order for a while. They asked in […]
[/quote]
I didn't bleach it, it's such a beautiful yellow, as if it came from the factory 😀
The attachment 1Awe_GUS_P-II.jpg is no longer available
Reply 29939 of 30668, by dominusprog
DarthSun wrote on 2025-08-01, 11:09:
[/quote]
No, the bezel is different, but inside was very similar. By the way, I would kill for one of those Creative drives 😁.
