First post, by pan069
I found this Cooler Master heatsink / fan combo and I want to clean it as it's a bit dirty. However, I'am having issues removing the fan from the heatsink. The fan is attached with plastic grips and I can't seem to be getting any movement on it (prying with a screwdriver) and I don't want to apply to much pressure as I am afraid it will cause damage.
There are also holes on the top of the cooler/fan and it looks like the pins that hold the fan in place. I am having a hard time figuring out this configuration. Has anyone have any experience with this type of fan / heatsink combo and the removal of the fan?
The attachment PXL_20250802_053928262.jpg is no longer available
The attachment PXL_20250802_053817483.jpg is no longer available
The attachment PXL_20250802_053857264.jpg is no longer available
Reply 1 of 3, by asdf53
Difficult to see from the photos, but could this be some kind of push-pin mechanism where the sides of the pins compress as they are squeezed through the hole and then expand to lock them in place? In that case, you would have to squeeze the sides of the pin together with pliers while simultaneously pushing it through the hole from above to release it.
Reply 2 of 3, by myne
Poke screwdriver in the top hole on the tight side, lever, pull fan up a bit.
Should get 1. 3 to go.
I built:
Reply 3 of 3, by pan069
Thanks for the advice guys. I managed to pry it off. The pins at the top don't seem to do anything much, maybe you need a special tool or something. Using a screwdriver (tried various sizes) didn't do much. Eventually, poking at the grips and applying a good amount of force with a screwdriver in one hand and trying to pull the cooler up at the same time was quite challenging all the while trying not to let the screwdriver slip and stab yourself in hand.
Eventually there was some movement and I was able to lift the cooler. Once the first grip was loose, the others starting to let go as well.
We now have a clean heatsink + cooler that can be put back to work... 😀
The attachment PXL_20250803_223010106.jpg is no longer available
The attachment PXL_20250803_223701456.jpg is no longer available
