First post, by Mourales
Hello everyone!
I'm currently working on a project with a 486 and I'm experiencing problems finding the standard AT MB standoffs for it. (I attach a photo)
I've been trying hard to find a seller in Europe or on Aliexpress, but so far I haven't had any luck. The regular non slide-in versions (with no peg) are fairly common, though.
I did find some options in the U.S., but shipping costs are insane...
Thanks in advance for your help!
Reply 2 of 6, by Mourales
Yep! Thank you very much! I
Reply 3 of 6, by Yoghoo
To add to that. If you 3D print them I would suggest using PETG. As PLA breaks very easily (at least that is my experience with this model). Also you need support and that can be a pita to remove.
Reply 4 of 6, by Mourales
Thanks a lot!
Reply 5 of 6, by Linoleum
I ran into the same problem and ordered some from Aliexpress for $3-$4: https://www.aliexpress.com/item/4001241127659 … .bd1d180286gV5p
However, I had to add some double-sided tape at the bottom... So that's the cheapo alternative.
P3 866, V3, SB Audigy 2
P2 300, TNT, V2, Audigy 2 ZS
P233 MMX, Mystique 220, V1, AWE64
P100, S3 Virge GX, AWE64, WavetablePi & PicoGus
486DX2 66, CL-GD5424, SB 32, SC55
Prolinea 4/50, ET4000, SB 16, WavetablePi
SC386SX 25, TVGA8900, Audician32+
Reply 6 of 6, by Mourales
Thank you ! I will try that idea too.
