Reply 2260 of 2277, by Lord Myn
Hi!
I like FSMP a lot, will it support VST3 instruments in the near future?
Hi!
Lord Myn wrote on 2025-07-22, 08:19:Hi!
I'm glad you like it but adding VST3 instrument support is very unlikely.
VST3 abstracted low level MIDI protocol away so VST3 is not very suitable for low level instrument plugins that try to emulate real synths ( like Munt VSTi, SC-VA, S-YXG50 ).
Even now you can use VST 3 plugins with the help of VST3 -> VST2 bridge plugins (such as Kushview's Element plugin) but in case of VST3 instrument plugins classic Midi Program change messages almost never work. And without supporting Midi program changes VST3 instruments are practically useless for Midi Player's real time Midi playback.
E.g. you can try such VST instrument plugins that have both VST2 and VST3 versions like ADLPlug
https://github.com/jpcima/ADLplug
You will notice that Midi Program change messages work only with the VST2 version.
More info:
https://www.un4seen.com/forum/?topic=19769.ms … 39331#msg139331
Falcosoft wrote on 2025-07-22, 08:56:Hi, I'm glad you like it but adding VST3 instrument support is very unlikely. VST3 abstracted low level MIDI protocol away so V […]
Even now you can use VST 3 plugins with the help of VST3 -> VST2 bridge plugins (such as Kushview's Element plugin) but in case of VST3 instrument plugins classic Midi Program change messages almost never work. And without supporting Midi program changes VST3 instruments are practically useless for Midi Player's real time Midi playback.E.g. you can try such VST instrument plugins that have both VST2 and VST3 versions like ADLPlug
You will notice that Midi Program change messages work only with the VST2 version.More info:
What's the best way to record the audio output of an emulator (which I am using MIDIplayer6 as the MIDI OUT) such as Nuked SC-55? (if possible). I obviously have no issues with SC-VA save for the wrong cymbal choke issue in the DOOM MIDIs, and that the SC-55 MAP is not as accurate as the Nuked ROMs.
Abu Brandino wrote on 2025-07-22, 14:34:...
If you have a soundcard with a working 'Stereo Mix' or 'What you hear' audio loopback recording source then you can use FSMP to record Nuked SC-55's output.
More info (more posts from the linked one):
Re: Nuked-SC55, low-level Roland SC-55mkII emulator announcement
Falcosoft wrote on 2025-07-22, 15:53:If you have a soundcard with a working 'Stereo Mix' or 'What you hear' audio loopback recording source then you can use FSMP to […]
What's the best way to record the audio output of an emulator (which I am using MIDIplayer6 as the MIDI OUT) such as Nuked SC-55? (if possible). I obviously have no issues with SC-VA save for the wrong cymbal choke issue in the DOOM MIDIs, and that the SC-55 MAP is not as accurate as the Nuked ROMs.If you have a soundcard with a working 'Stereo Mix' or 'What you hear' audio loopback recording source then you can use FSMP to record Nuked SC-55's output.
Unfortunately I don't because I uninstalled the Realtek drivers because of bloat. I've got an SC-88 Pro that I am going to Voltage mod for 240V and I bought a SoundBlaster AE-5 Plus to record it. Gonna use your MIDIplayer to do all that once I got it all sorted. That way I won't have to stress with the Roland Auth server bs or improper instrument playback.
I didn't know this about VST3 (as a matter of fact I didn't know what is the difference between VST3 and VST2 exactly). I asked it, because I've found the FSMP very handy to work together softsynths like SCVA, HyperCanvas or Proteus VX and I wanted to give a try with Zenology, which has no VST2 variant, but without low level MIDI protocol, it's no useful for me anyway. Thanks for the information.
Abu Brandino wrote on 2025-07-22, 14:34:What's the best way to record the audio output of an emulator (which I am using MIDIplayer6 as the MIDI OUT) such as Nuked SC-55? (if possible). I obviously have no issues with SC-VA save for the wrong cymbal choke issue in the DOOM MIDIs, and that the SC-55 MAP is not as accurate as the Nuked ROMs.
For this you can use http://vincent.burel.free.fr/VirtualAudioApps … Setup_v1007.zip this cable can write sounds on loopback and simply in use )
Roland User wrote on 2025-07-24, 11:25:Abu Brandino wrote on 2025-07-22, 14:34:What's the best way to record the audio output of an emulator (which I am using MIDIplayer6 as the MIDI OUT) such as Nuked SC-55? (if possible). I obviously have no issues with SC-VA save for the wrong cymbal choke issue in the DOOM MIDIs, and that the SC-55 MAP is not as accurate as the Nuked ROMs.
Thanks man. But I now have a physical SC-88 Pro I can run in 55 COMPAT mode and it's better than any software emulation can be.
This is very good )
Falcosoft wrote on 2025-07-14, 21:50:2. I do not think there is a simple setting in Wine that can cure this error. The error occurs because Wine never implemented the classic Windows mixer API correctly.
I know I am quite late...
Would it be possible to make the source code open-source?
Why I asked it is because I wanted to give a try porting it to Linux.
I know this is a niche feature request, but will it be possible to setup MIDI playback over serial?
My fork of Nuked SC-55 supports serial mode and would love to use this MIDI player instead of going through DOSMID+86Box/DOSBox route.
linoshkm wrote on 2025-07-30, 13:19:I know I am quite late... […]
Why I asked it is because I wanted to give a try porting it to Linux.I know this is a niche feature request, but will it be possible to setup MIDI playback over serial?
1. Unfortunately no. BTW, the program is not written in C/C++ but in Delphi. So a Linux port would be rather hard even if the source could be shared. The only option would be Lazarus since Kylix was killed 20 years ago. But even porting the source to Lazarus/Linux would be a hard work since FSMP is rather low level so it uses low level Windows multimedia API functions directly.
The open source problem is twofold. It uses some third party non-open source copyrighted components, but this is the smaller problem. The bigger problem is it also uses heavily modified Borland/Inprise Delphi(5!) VCL source codes. Some modifications are compatibility/bug fixes, some are necessary hacks to add new features (and Borland's code of course cannot be distributed)...
FSMP started as a hobby project for myself and for my SB Live! about 20 years ago. Multi-platform/open source compatibility was not a concern then.
2. Maybe later, but honestly I do not understand what benefit serial connection could offer in case of FSMP + Nuked SC-55.
FSMP and Nuked SC-55 work together perfectly with the help of LoopMidi as far as I can tell. The same is true for DosBox + FSMP. You should share some more details to increase my motivation for adding direct serial support. 😀
Falcosoft wrote on 2025-07-30, 14:36:1. Unfortunately no. BTW, the program is not written in C/C++ but in Delphi. So a Linux port would be rather hard even if the so […]
My fork of Nuked SC-55 supports serial mode and would love to use this MIDI player instead of going through DOSMID+86Box/DOSBox route.1. Unfortunately no. BTW, the program is not written in C/C++ but in Delphi. So a Linux port would be rather hard even if the source could be shared. The only option would be Lazarus since Kylix was killed 20 years ago. But even porting the source to Lazarus/Linux would be a hard work since FSMP is rather low level so it uses low level Windows multimedia API functions directly.
FSMP started as a hobby project for myself and for my SB Live! about 20 years ago. Multi-platform/open source compatibility was not a concern then.2. Maybe later, but honestly I do not understand what benefit serial connection could offer in case of FSMP + Nuked SC-55.
Can't be helped I guess.
Regarding Serial Support, like I said, it will be a niche feature. There is no benefit over MIDI. Just more problems to be honest. MIDI is standard and more well implemented than Serial in case.
Falcosoft wrote on 2025-07-10, 12:31:Hi,
1. Thanks for your kind words.
Here is a new test version that saves and then restores the state of Midi net send/receive at startup.
Kind, though those words may be, they are also true. You are a hero in this niche, and I don't think that overstates things at all. 😀
I just tested the changes you made, it seems to work perfectly, remembering both the MIDI In and Network MIDI settings. Thank you so much.
I can even set MidiPlayer to start minimized and the whole setup starts more or less automatically at boot, which I did while I was testing the setup. Hopefully the feature will prove useful for other people using your software as a MIDI router. Using virtual MIDI loopback ports on the VM guest, it should be possible to make something like the "Ultimate MIDI emulator" project for VM or guests, without any extra hardware, using the same technique - indeed I tested it with Nuked-SC55, MUNT and Timidity running on the host OS and all worked flawlessly; An Ultimate MIDI emulator emulator of sorts. 😁
One more question, if you don't mind. Is there a way to completely disable output on the local side when I'm sending over the network? (I tried pointing the local midi output to the unpopulated "Ext Synth" port on the VMware guest and it caused MidiPlayer to crash - probably a Win98 feature. I then tried outputting to Bassmidi without any instruments loaded, which works, but seems to cause weirdness with other apps that want to output audio). I can always mute the synth in the mixer on the guest, but I'd prefer not to waste any CPU time needlessly generating waveforms that are just going to be discarded.
Thanks again.
steviant wrote on 2025-08-04, 22:27:... One more question, if you don't mind. Is there a way to completely disable output on the local side when I'm sending over t […]
Here is a new test version that saves and then restores the state of Midi net send/receive at startup....
One more question, if you don't mind. Is there a way to completely disable output on the local side when I'm sending over the network? (I tried pointing the local midi output to the unpopulated "Ext Synth" port on the VMware guest and it caused MidiPlayer to crash - probably a Win98 feature. I then tried outputting to Bassmidi without any instruments loaded, which works, but seems to cause weirdness with other apps that want to output audio). I can always mute the synth in the mixer on the guest, but I'd prefer not to waste any CPU time needlessly generating waveforms that are just going to be discarded.Thanks again.
Yes, The Bassmidi/VSTi output mode has a 'No Sound' virtual device. It's the 1st one in the list of the 'Output Device' combo box.
Falcosoft wrote on 2025-08-05, 09:38:steviant wrote on 2025-08-04, 22:27:... One more question, if you don't mind. Is there a way to completely disable output on the local side when I'm sending over t […]
Hey mate, what’s the settings to be mindful of when recording from my physical sound canvas unit?
Should I enable “Use SysEx for Volume/Balance” and turn the physical volume knob to max (or 50% or 75-80% not sure recommendations welcomed). Is there anything else I need to look out for?
Abu Brandino wrote on Yesterday, 16:32:Hey mate, what’s the settings to be mindful of when recording from my physical sound canvas unit?
I'm sorry but I have no direct experience with hardware unit recordings.
Falcosoft wrote on Yesterday, 20:46:Abu Brandino wrote on Yesterday, 16:32:Hey mate, what’s the settings to be mindful of when recording from my physical sound canvas unit?
Should I enable “Use SysEx for Volume/Balance” and turn the physical volume knob to max (or 50% or 75-80% not sure recommendations welcomed). Is there anything else I need to look out for?I'm sorry but I have no direct experience with hardware unit recordings.
What is that feature supposed to be for?
Abu Brandino wrote on Today, 03:06:Falcosoft wrote on Yesterday, 20:46:Abu Brandino wrote on Yesterday, 16:32:Hey mate, what’s the settings to be mindful of when recording from my physical sound canvas unit?
Do you mean 'Use SysEx for Volume/Balance' ?
It is for any synths (be it a soft synth or a hardware one) that support GM Master Volume/Balance SysEx messages. If it is enabled then changing the Volume and Balance sliders sends the corresponding SysEx messages instead of setting the Windows/Bass mixer values (which are useless in case of external synths). Also a fundamental difference is that SysEx Volume/Balance messages change the volume before mixing so they can prevent clipping.
