First post, by kolderman
Do the vrms draw 5v like AXP, or do they still take 12v but from 20pin connector?
Reply 1 of 4, by Archer57
Usually no extra connector means 5v, there is only one 12V pin in 20pin ATX connector, that is not enough to power 60-100W CPU.
You can figure it out with reasonable degree of certainty by looking at VRM input capacitors - if they are something like 16V it is likely to be 12V, if 10V or lower it has to be 5V...
Reply 2 of 4, by kolderman
Says 6.3v so I guess that answers it...
Reply 3 of 4, by dionb
Out of interest: what motherboard is this? No ATX12V sounds pretty unusual.
Reply 4 of 4, by kolderman
ECS P4VXAD
And it is unusual. Only one I have seen like it.
