First post, by superfury
Do Sound Blaster commands interrupt the DMA ADC burst command?
If an ADC burst command is active, is the status register always indicating a byte to read (bit 7 set)?
Does command 0x04 work when said command is active? Do other commands end said command?
All I can find out about it is that the DSP can probably interrupt it using command 0x04 to indicate it's active (bit 3 set, meaning "Direct ADC, 8-bit burst", source https://the.earth.li/~tfm/oldpage/sb_dsp.html)?
What happens with other commands sent?
UniPCemu Git repository
