candle_86 wrote on 2025-08-12, 11:36:
DDR3 benefits it massively. As someone who was on Phenom II until 2013 and still onto a living room HTPC until 2020 DDR3 helps a lot. In software from 2008 no it won't show a benefit but even tests in 2010 and 2011 showed 10-15% difference in performance between the same Phenom II on DDR2 and DDR3. Phenom II was good realistically until 2015/2016 when games started requiring instructions it didn't have, for the average person a good Phenom II X4 + 8gb DDR3 was all they needed, the DDR3 also let them beat the Core2 Quads finally, and the i5 6xx cpus, and don't forget later in life the Phenom II X4 competed with the i3 2xxx and it was a tossup in performance while the X6 competed with the i5 2xxx and they traded blows depending on workload.
As for viability for retro rigs, it really depends on what your after, I've got one rocking a Phenom X4 9500 just because i can.
Phenom II X4 955 BE with 4x DDR2 800 unganged running at 4 4 4 12 has memory bandwidth 9.75GB/s, 77% bandwidth efficiency in SiSoft Sandra 2013. It isn't that good, in Athlon XP times we saw much better values in terms of efficiency. It is even worse in Everest. My measurements showed it depends also on CPU clock speed and uncore clock (just 2 Ghz for Phenom II). Low clocked Athlon 64 barely benefited from DDR2, especially 667. These benchmarks also contain measurements for DDR3 and it isn't that great for Phenom II. I don't have the exact value but bandwidth efficiency is very low.
See Re: Any love for AM2? and Re: Any love for AM2? for comparison of Athlon 64 X2 6000+, GeForce GTX 480 (we are CPU bottlenecked) with DDR2 800 and DDR2 1000. See 3d mark 2006 breakdown, 1024x768. We added 20% memory bandwidth and didn't get much back in exchange.
My testing showed a CPU like AMD Phenom X4 9500 is not a good choice for Windows XP retro gaming because the CPU clock is too low.
The Serpent Rider wrote on 2025-08-12, 12:30:
Phenom II north bridge/L3 cache work at 2 GHz, so unless NB part is overclocked, it does not benefit much from anything beyond DDR2 1066 MHz.
That is consistent with my findings. It seems one could run Phenom II X6 on AM2+ at DDR2 1066 and not be bottlenecked. DDR2 1066 would provide theoretical 8533MB/s with unganged memory controllers, so for each CPU core separately, with up to 2x in total bandwidth. The value I measured represents bandwidth for all cores simultaneously.
For reference SiSoft Sandra 2013:
- cache bandwidth L1: 248GB/s, L2: 122GB/s, L3: 42GB/s
Main benefit of DDR3 for Phenom II is higher memory capacity.
Pentium III 900E, ECS P6BXT-A+, 384MB RAM, GeForce FX 5600 128MB, Voodoo 2 12MB, Yamaha SM718 ISA
Athlon 64 3400+, Gigabyte GA-K8NE, 2GB RAM, GeForce GTX 275 896MB, Sound Blaster Audigy 2 ZS
Phenom II X6 1100, Asus 990FX, 32GB RAM, GeForce GTX 980 Ti
