What modern activity did you get up to today?
Reply 1380 of 1390, by chrismeyer6
Nexxen wrote on 2025-07-29, 22:32:
Yep, the PCIe lanes are the ones of the slots connected to the cpu. I'm not concerned, it isn't affecting the results one bit. […]
chrismeyer6 wrote on 2025-07-29, 21:43:
Nexxen wrote on 2025-07-29, 21:23:
I bought a 3rd graphics card from Sapphire, RX 5600XT Pulse. I alredy have 2 same model. This one was cheap and I made a windows […]
I bought a 3rd graphics card from Sapphire, RX 5600XT Pulse. I alredy have 2 same model. This one was cheap and I made a windows only gaming rig.
Even this 3rd card instead of PCIe 3x16, it show 8x. Not a problem, they output the same results with usual statistical variations (all in line with general results).
I'm starting to think that something is wrong with the 2 mobos I tried them on, X370 + 3600X and B450 + 2600.
Both cpus are capable of PCIe 3 16x.
I tried multiple OSs and programs, all showing the same 8x.
Other cards show PCIe 3 16x. I am truly puzzled. Makes no difference, but on an old i5-6xxx they are reported 16x.
Old i7-3820, 16x.
Is intel beating Amd on its turf? 🤣
Is the slot on your motherboard actually an x16 slot? A lot of times you can have a full length slot and it only have pins for 8x, 4x , or even 1x. Check the slot and see how many pins are in it.
IIRC a RTX 2080 isn't maxing out the bandwidth of a PCIe 2.0 16x. Thus 3.0 8x is totally fine for this card (like a 2060 performance). It's 6GB GDDR6 192 bit.
I understand that it's not a performance issue I'm just more curious if that 16x slot is actually wired for the full 16 lanes. More just morbid curiosity
Reply 1381 of 1390, by Nexxen
chrismeyer6 wrote on 2025-07-29, 22:35:
I'll have to check the cpu socket.
If it's not an error of some sort on the BIOS-Cpu-program, probably a broken lane. And that can be, absolutely.
Tomorrow I'll pester my dad to test it 😀 What are dads for??? 🤣
I'll also check the second motherboard.
It makes non sense. Also it could be a dead demux.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Reply 1382 of 1390, by chrismeyer6
Not the CPU socket you need to check the pci Express slot itself. Not all full size slots have all the pins populated. Asus has some mid range Intel b850 boards with full size 16x slots but only wired for 1x and the rest of the slot has no pins.
Would you mind posting a picture on the 16x slot?
Reply 1383 of 1390, by StriderTR
Ordered a pack of 600 colored jumpers ... set for life! 🤣
Sorted some of my parts shelves. Much better than before.
Ordered a 16GB eMMC module for my Le Potato. Not 100% sure what I'm going to use it for now.... Portable SDR station? Dedicated DOSBox machine? OctoPie server for one of my printers? Either way, eMMC is faster than an SD card. I do like the Le Potato, similar to Pi 3B+, but less power draw and 2GB DDR3 RAM vs the Pi 3B+ 1GB DDR2, same basic footprint.
Builds: https://theclassicgeek.blogspot.com/
3D Prints: https://www.thingiverse.com/classicgeek/collections
Wallpapers: https://www.deviantart.com/theclassicgeek
AI: https://creator.nightcafe.studio/u/StriderTR
Reply 1384 of 1390, by GigAHerZ
Released ByteAether Ulid v1.3.0.
Blog post: https://byteaether.github.io/2025/byteaetheru … l-and-security/
Did quite an overhaul on the generation/creation part of the ULID. Better than ever before! 😀
Reply 1385 of 1390, by Nexxen
chrismeyer6 wrote on 2025-07-30, 00:59:
I tested one GPU with Z75 (3rd gen i-5) and Z87 (4th gen i5), both PCIe 3.0 x16 lanes.
GPUz detects PCIe 4.0 @ x16 running PCIe 3.0 @ x16 ---> values that never change, not at idle or 100% under stress. With 2n x16 slots it is detected running @ max speed allowed (both PCIe 2.0 @ x4) and results are lower than expected. But consistent between them.
I tested the GPU with 3DMark 11 and results are consistent with other cards' results. This is probably just a glitch and I should probably stop wondering.
HW monitor is the same.
IDK how GPUz and HWMonitor work but probably they use the same system to check lanes? If I'm wrong correct me, I'm clueless on this subject.
My guess spans from m/b bios to gpu bios.
There have been many updates and who knows if by flashing the latest version I just introduced a bug.
Who knows! - Prof. Farnsworth
Reply 1386 of 1390, by UCyborg
Converted Smart Preview for Pale Moon forum, a XUL bootstrapped extension, to a user script.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 1387 of 1390, by lti
I tried some of those gaming keyboards when I was in Best Buy on Sunday. I wasn't expecting the different switch types (at least the ones on display) to have similar noise levels or tactile feel. They do have different noise characters, but the "clicky" sound was a different type of obnoxious high-pitched metal-on-plastic tapping noise than I expected. The MX Red clone switches have a better-sounding click, but they still seemed loud. At least they feel smoother than the random cheap rubber dome keyboards I've been using (full-size ones, not the ultra-thin ones).
Yes, I've seriously never used any kind of "mechanical" keyboard (never mind that rubber domes are mechanical parts) since Alps switches were still common.
Reply 1388 of 1390, by UCyborg
lti wrote on 2025-07-28, 21:53:
UCyborg wrote on 2025-07-28, 17:04:
Dealing with bugs and staring at the code for hours with nothing to show for it. Is it still better than dealing with idiots and annoying people? I don't really know.
You're still working with idiots, but now they're in upper management. I had a health scare after hearing the VP in one of those all-employee meetings last spring.
I tried to take a few days off, but nothing really sounded interesting, especially with the extreme heat that is now normal (and even the most extreme climate change activists deny how much temperatures have actually increased). Then I saw a weird bug at work (the kind that makes even less sense as you keep testing and leads you to some ridiculous potential causes), and I want to see what happens.
Small companies seem to be their own kind of hell. I recently notified the developer of the issue with labels not being associated with checkboxes on one form in the internal application we use. He fixed it, then reverted it because the moron from another department told him to (the developer himself thinks the association makes sense). WTF? Have you seen a program where clicking the label associated with checkbox doesn't trigger the checkbox? It's one of the first accessibility guidelines, makes it easier to click since you don't have to strictly target that square. And it helps assistive technologies. Would a sane person go out of their way against it?
Reply 1389 of 1390, by lti
This is a big company, but I shouldn't go into too much detail when I'm talking about upper management online.
The weird stuff I saw at work really was the ridiculous answer. A bug in the development software resulted in hardware damage.
My work computers are both broken, and my personal phone is giving me an Android update alert in Spanish. Then I'm waiting for the rainforest idiots to ship one of those shitty cheap power meters so I can see if my big Ryzen is really heating the room or if I'm full of shit. I ordered it a week ago, and when it finally does ship, it will probably be put in either an envelope or a huge box with no packaging material.
Reply 1390 of 1390, by lti
I took my computer outside to clean it, and even the outside of the case is warm around the "extremely efficient" CPU and motherboard VRM. Something is seriously wrong. I think MSI is fucking with power limits and overvolting, but everyone is pretending that that's an Intel-specific problem. Now what?
