AlexZ wrote on Yesterday, 20:18:
It made a similar airflow fix in my older GeForce 9800 GT. The original fan was small, noisy and could not be fixed. I used a slim fan though as full size fan would have produced too much noise from sucking air through the little space available. I need 2 PCI slots below PCIe. I also used just plastic strips for fastening.
This was a little more than airflow fix, here is the original cooler:
The attachment 20250818_113730_D.jpg is no longer available
The attachment 20250818_113712_D.jpg is no longer available
That cooler i installed was from HD6850 or something like that. Required a bit of modding too since it did not clear all the components (original cooler actually has cutouts for them too).
Since i have standard ATX board and only going to use one PCI for sound i did not really care about size here...
Having now tested the card like this i also wonder - were the pads for the memory simply a marketing feature? Were they useful? Were they harmful? The memory is barely warm to the touch, while with that original cooler it was heated up by GPU to the point where whole card was too hot to touch under load...
There is a reason why I went with s754 3400+ with 1MB cache. I just don't trust AMD optimizations that are supposed to be worth the extra 512kb L2 cache, similarly to Brisbane vs Windsor. In the case of s939, it's the same technology. Always go for 1MB L2 cache per core.
For s939 to be meaningful it should beat s754. This means you need Athlon 64 X2 4800+, pcie and GeForce 2xx or better.
Yeah, this is the issue which was discussed in this thread regarding S462, S754 and S939. Despite all its advances like x64, integrated memory controller, instruction sets, etc neither S754 nor S939 were a reasonable upgrade for high-end S462 at the time. Take a look at performance of any single core athlon64 with 512KB of cache and 2.2Ghz or less and gains compared to 2.2Ghz AthlonXP would be... very small. And 1MB 2.4Ghz models were the very top end and quite expensive, while still being only marginally better.
The only real significant change was pci-e, but while it certainly is beneficial now back then it was less so. This forced card replacement and also at that point all the stuff was still coming out in both variants with very similar if not the same performance, so instead of replacing whole system old one could simply be upgraded with new GPU...
Dual cores were meaningful since they provided other benefits - they radically improved general experience using the system and multitasking. But the cost on S939 was ridiculously high and single thread performance still very similar...
Real significant improvement happened with AM2 - DDR2, higher frequencies, reasonable prices...
Cost wise s939 doesn't seem to be practical as 4800+, 4400+ with 1MB L2 cache per core are stupidly expensive, just like they were back in the day. Opteron 156 3Ghz isn't available at all. You are lucky to have that 4800+.
I am fully aware that S939 is not a sensible platform to build. Funnily enough it never was. And yes, i wanted that 4800+, that's why i waited so long...
It is fun though. Really cutting edge hardware back in the day, something most people were not willing to spend money on, but also a glimpse into the future with dual cores which only became mainstream a couple years later with AM2.
How awesome is that - being able to run a browser, a music player, monitoring tools, etc in the background while playing a game without it affecting the performance? We are used to it nowadays, but back then it felt like magic...
Small fun fact - this athlons advertise that they have hyperthreading to the OS in order to gain benefits from optimizations intel and microsoft worked on for P4HT.
