Reply 1 of 8, by Qbix
- DOSBox Author
ctrl-f9
Maybe it is correct if you use the guide in guides forum of vogons ?
Water flows down the stream
Reply 2 of 8, by themagicalmoose
I'm having this same problem. Can anyone help?
Reply 3 of 8, by h-a-l-9000
Use CVS build
and don't use the command line in Windows it's not supported in DOSBox.
1+1=10
Reply 4 of 8, by themagicalmoose
okay, i'll try that. thank you. i'll comment again to verify if it works.
Reply 5 of 8, by Neville
- Oldbie
Many "Windows" games are just DOS games with a PIF file and an icon tagged on. My guess is that you ran into one of those.
As h-a-l-9000 said, DOS stuff under Windows 3.1 is broken for the time being.
Reply 6 of 8, by darkromis
install windows 3.1 as this page says Windows 3.1x DOSBox Guide i followed all installation steps and i don´t have that problem which i used to have
Reply 7 of 8, by butterfly
- Member
wrote:i had resently try windows 3.1 under dos box and it works great but is it perfict for playing games i mean i tryed and it works but one the game has quit windows 3.1 is all scrwed as you can see.
I remember having similar issues on an actual machine. Video board issues, I think
Reply 8 of 8, by h-a-l-9000
That screen is what happens when it tries to display a 256-color image with the graphics card set to 16 colors.
1+1=10
