Socket3 wrote on 2025-08-16, 20:17:
You're kidding right? I have a 5700XT Anniversary Edition - bought it new. Worked flawlessly then, and still does in my sister's PC, 6 years later. There must have been something wrong with your sistem.
Nothing wrong with the system. It worked just fine with RX580 for a few years before and still works fine with RTX2080s which replaced 5700XT back then. I never wanted to buy 2080, i thought it was not a good value, but AMD forced me...
And yeah, i am not going to buy another new AMD card for a long while after that experiment. Enough is enough. Good thing intel cards now exist so i can safely say i am not an nvidia fan 😁
I never had an issue with AMD video cards or drivers from the HD7000 series up to today (running a 6900XT), and I've setup countless builds in the last 14 years. On the other hand, I've had plenty of issues with nvidia drivers, like the WHQL certified Geforce 196.75 drivers stop some graphics card fans from spinning. Killed my GTX 260 while playing bloody wow. Current nvidia drivers are lovely. Google "nvidia black screen issue".
Yep, nvidia made some fun mistakes too. Another example was their drivers deleting current user's home folder on linux.
That's the reason i update drivers like once a year at most. If you update to each new version you are guaranteed to experience all the bugs. If you skip most updates you skip most bugs. I was using nvidia card when they screwed up with fans, never got the faulty version...
You need to use the drivers your manufacturer supplies for the card. I have a 2600XT AGP and a 1650XT AGP - none of them work correctly with generic AMD Catalyst drivers. For my 2600XT I used the drivers off the HIS website - version "XP_8.401-070727a-050964C-ATI with WHQL". Test system was a Pentium 661 + Abit AS8-V, XP32 and 2GB of ram. Tried Far Cry (1), Doom 3, Quake 4, Company of Heroes and C&C3.
AMD never bothered properly supporting the AGP versions of 2xxx cards. I'm not 100% on this, but I remember all AGP versions of the 2600 are based on a beta driver witch is then modified and re-packaged by each card's manufacturer. It's possible some manufactures did a better job then others with these drivers.
If you look through the thread further - a lot has changed since me posting it. Short summary: nothing to do with drivers, everything to do with hardware level incompatibility. I still blame AMD though, because when you have a system (or multiple systems) which works perfectly with every other card including old ATI radeons but then does not work with AMD HD**** stuff the conclusion is pretty obvious.
Also yes, AGP cards work just fine with generic drivers, the only issue and the only "fix" card manufacturers did is the fact that device ID is different and installer does not "detect" the card. There are a few ways around that.
I've since tried the card on asus a8v and it works fine with any driver, apart from various driver bugs, but that's normal.
That said AMD never bothering to make drivers work for AGP cards also shows pretty well how much they care about their customers.
