First post, by Paar
- Member
Do you know about any mATX boards with socket 478 and an Intel chipset which can at least manipulate a FSB setting? For now I have tested Asus P4GE-MX and P4p800-VM and both are very limiting.
The former does contain an option to manipulate FSB but only from the default value up (e.g. put a 533Mhz Celeron D there and could put a value from 133 to 165 MHz FSB). The latter doesn't contain any underclocking at all.
Reading through manuals it seems that Asrock P4i65G and some Biostar boards with Intel 865 chipsets allow FSB manipulation but I don't want to buy any board in blind faith. Could someone confirm that I can put a 800MHz FSB CPU in there and underclock it with 400MHz FSB setting? Of course it would be nice if there were any board which could lower voltage as well but I have to be realistic - mATX boards in that era were mainly for OEMs and were very berebones.
