Reply 40 of 62, by Joseph_Joestar
Sombrero wrote on 2024-03-06, 05:32:
Not sure what subhuman@xgtx means, but some older games do force that back on while playing least on Windows XP and beyond causing mouse acceleration. Fairly sure games like UT99, HL and Deus Ex do that.
But there is a fix for it. Also contains a .reg for WinXP even though it speaks about Win7 and up on the title.
Interesting. I wasn't aware that games could override system settings in that manner.
And cheers for the fix, I'll definitively be using that on XP and 7.
Reply 41 of 62, by Sombrero
Joseph_Joestar wrote on 2024-03-06, 06:47:
No problem. Ran into that years and years ago when I tried to revisit old games on my then modern PC.
Mouse acceleration is the biggest pain in my ass I've had ever since I turned into a PC gamer and I'm on an eternal crusade against it. I really would like to ask developers what the &#@% are they even doing who even today turn it on by default or even worse FORCE it on.
Reply 42 of 62, by DracoNihil
Sombrero wrote on 2024-03-06, 07:02:
USB mouse polling rates above the stock default 125 Hz also cause a slew of problems, and I have to use a hack implemented via a DKMS module to force my current mouse to poll at 125 Hz because Linux's XHCI host drivers don't obey the "mousepoll" options. (Which makes me wonder why the hell the option continues to exist if it does NOTHING)
I'm also going to blame the netcode in UT99 as to why it's "difficult". I've had far better luck playing Unreal 1 deathmatch on 224 and 225 versioned servers compared to the spaghetti code UT99 runs on...
― Κυνικός Δράκων
Reply 43 of 62, by Dolenc
In any case, whateverthefuck you do...
Its gonna run better on a new-er system with later patches that break win98 compatibility. The mouse input will be more responsive.
The only reason to even play it on an older OS, in MP form, is to enjoy some a3d asmr.
Reply 44 of 62, by Sombrero
DracoNihil wrote on 2024-03-06, 09:30:
Linux seems a bit odd with these things. I used to try out some linux distro every few years to see would I actually like to use it just to notice horrible mouse acceleration right off the bat without any way (that I knew of) to disable it. Only recently I've learned that KDE has a built in way to disable mouse acceleration while gnome doesn't for some extremely baffling reason.
And speaking of USB polling I actually used to have a system that sometimes freezed during boot if I had my mouse of the time set to 1000hz. I still don't increase it above 125hz even though I definitely do notice the difference.
Reply 45 of 62, by DracoNihil
Sombrero wrote on 2024-03-06, 16:49:
The mouse polling rate thing isn't even a Linux problem. Very old games absolutely do not like when certain input events happen way too quickly. LithTech engine games will completely break and may even misbehave so badly as to reduce your FPS to sub 20 when certain input polling rates are setup.
I don't have as much mouse problems with Unreal Engine 1 games when things operate at 125 Hz in general, but there is very subtle nuances in functionality if you jump that to the 1000 Hz a lot of modern mice seem to constantly demand the system to set it to...
― Κυνικός Δράκων
Reply 46 of 62, by nezwick
Well a small update to the conversation:
I reinstalled the graphics drivers for my x800 and now the framerates in UT ride the 85 FPS limit all day. That did make gameplay noticeably smoother. Maybe once I work out some of these technical issues, I can focus on becoming a better player. All the good hardware in the world can't help me from getting stomped by the experts though!
XP: A64 3000+ S754 / 2GB DDR / 500GB SATA / Audigy1
2K: AXP 1700+ @ 1900+ / 1GB DDR / 120GB IDE / X800XL / Audigy 2ZS
98SE: Duron 900 / 512MB SDR / 20GB IDE / Voodoo3 3000 / Vortex2
95: P200 MMX / 128MB SDR / 6GB IDE
DOS: NEC PowerMate 1 / 286 / 640k
Reply 47 of 62, by Jonsmith0815
You have to use an optical gaming mouse. For example something like zowie ec1b. With a ball mouse you will never be happy in online games.
Reply 48 of 62, by oeswapi
made an account specifically to reply to this
i'm a comparatively new ut99 player only playing because my dad showed me it as a child, i'm 23 years old.
I play ut99 competitively in tournaments (yes they still happen in 2025) both duels and ctf's on a rtx 3060TI 1000hz mouse 1200 dpi and keyboard with a 240hz 1920x1080 monitor with a hyperx headset with a fully tweaked out ut99 client for maximum performance and advantage. I have 12+ years of tryhard fps experience with most arcade shooters i average around a 2 - 6kd. This is a pretty common setup and story for a ''good'' ut99 player today, peripherals and client matter A LOT and most newer players play ut99/quake knowing this is where the good fps players are. I purely got into ut99 because i knew it would have good players. Playing on windows XP with most likely a crap mouse and kb from 2006 and expecting to be good is so beyond stupid i can't even tell you not trying to be mean.
I am most likely a player you would feel like is cheating, i have been both banned once (unbanned now) and hackusated by older veterans, i usually either am top 3 in ctf/dm or first, so listen to me
lets get the ignorant insecure shit out of the way first, cheating is rare it doesn't happen often.. over the years the community has developed numerous ''ways''..... to figure out the legitimacy of someones gameplay through things like registering exact shot locations with a rigid aimbot always having the same coordinates of course spectating being effective as well but there also ways to list executables connected to the process of someones client and detect memory injections such as dll's which is the job of an ANTI CHEAT. Of course, there are bypasses and people don't get banned instantly and some cheats are more hidden as there are numerous expert scripters and coders playing UT99 today that can develop unique undetectable scripts and exploits. Having played ''competitively'' in tournaments and pugs for a while now i've only witnessed 2 real cheaters in the last 5 years, realistically i would up that number to maybe 5 with a few possibly having wallhacks or some other unique less advantageous cheat.. but let me make this clear cheating is RARE not nearly rampant enough to be used as an excuse.
using ''cheaters'' as an excuse is so common by skilless players now, you actually see more hackusators than actual hackers typical for fps games and the thing is they are almost always very bad players. It is YOU, you are bad. You've missed out on years and years of FPS development or you simply don't try hard enough or you simply aren't built for it.
You have to realize that it is 2024, 2025 at the time of commenting this.. a large portion of the ''expert'' players you are playing against are young guys 18 - 30 with insane setups with perfectly tweaked ut99 setups for competitive play who have been playing shooters or ut99 since a child as in my case, when i started playing ut99 back in 2020 i could beat 90% of pub (public matches) players instantly like you with aim and speed alone always being top 3 or first in dm's and ctf matches. I have everything fully tweaked out including my pc and ut99 client. This gives me smooth aim, close to instant input, directional clear audio, i have around 1000 fps with a 240hz monitor that basically gives me instant visual feedback, i have everything keybinded, i have all visuals such as shadows and brightness tweaked so i can see everything better, i have 120 fov ... i have at least 12+ years of tryhard FPS experience.. and you know how it goes with children that learn something from an early age. I know where you're going, i know where you're going to spawn, i know where every weapon is, i know where you're probably going to go, i know what when and how and i know how to execute things so i can kill you.. and i'm definitely not the only one that knows this.. this is called ''gamesense'' combine that with good aim fast movement and i will always beat someone like you. This is how you should approach ut99 in 2025, expect everyone to be a godlike killer machine compared to the 2000's, not cheating. If you wanna be certain make sure you're up to par yourself because you can't judge without knowing what you're talking about and like you said you have always been an average player even back then.
UT99's community is a mix of Veterans and young players with the younger ones most likely playing ut99 because they did so as a kid or know someone who did, i only know a few older veterans that truly excel in 2025, you would expect all the veterans to beat the newer players but that's just not how it goes if you can't adapt to the new tech and haven't been exposed to the competitive nature of modern fps games. After ut99's/quake/arena shooters rise and fall the fps genre became insanely competitive and rigid and everyone had to try harder each year as everyone got better, so the longer you've been playing since then, the crazier you are. You would need to have been truly godlike back then to beat a decent player now without too much adaptation in peripherals and branching out in fps games, most likely relying on map control. That is how much the skill ceiling has grown specifically in Aim and Movement there is just no way you can compete if you haven't been playing. It is pretty common to see names you've never seen perform very well with good aim and movement and you can basically assume they're young-ish new players coming from other fps games out of curiosity.
Now this all sounds dramatic, but there is a beauty to it as well, you will see the true final potential of UT99's gameplay if you spectate a good 1v1 duel between 2 skilled players just look up a modern duel video on youtube. Okay sure, i might not have been able to convince you yet but not everyone can be cheating right? Join a deck-16 server and just spectate some players, you will start to see the difference in movement and aim with the worse players usually being the ones refusing to adapt to new tech new clients.. you will see it in roughness in their aim (either no raw input, old client, or bad mouse) with the crosshair snapping all over the place, lack of mirroring in movement (mirroring is essentially guessing where the enemy is aiming and moving the other direction to throw off their aim, modern technique, also a form of gamesense) general lack of speed and control over where they're going.
If you really wanna compete and not delusion yourself into thinking every good player is a cheater, get a modern computer download a tweaked out client from a pub servers discord and work on the fundamentals like aim, movement, map control.. spend a year doing that. it's not even age that matters, as the difference is only in reaction speed which is milliseconds anyone can move a mouse around everyone has muscle memory and everyone can press keys and in an arena shooter you can dominate with pure map control and tacticality, you can train your aim in Aimlabs or Kovaaks, and you can practice movement in the thousands of bhop maps. But you won't do that and the good players will do that and then players like you will wonder how it is even possible to play like that and call every second good player they face a cheater in chat.
Again, i've only seen 2 real cheaters in 5+ years in the most competitive side of ut99. Surprisingly the game still has a decently active administrative presence with those 2 cheaters being gone in a day and the other in a week. Haven't seen a single cheater in a long long time.
TLDR; you're inexperienced, playing on an ancient egyptian setup, cheating is rare, get better.
peace
Reply 49 of 62, by Lutsoad
So it's like F1: if you have a good car you win, skills are basically secondary.
That's the reason I loved those old high school LAN parties back in the 2000's, everyone had the same rig and we played the basic maps. Sometimes you lost and sometimes you won, it was so much fun! Now it's all about scripts and mods and FPS and whatever hardware you could buy.
Reply 50 of 62, by gerry
oeswapi wrote on 2025-08-18, 23:20:
peace
Lutsoad wrote on 2025-08-19, 08:06:
I think there is a standard of skill required. A pro driver will beat an amateur even if given the lesser car in a race. The marginal advantage of the set up is only effective for the elite
The set up is important though, remember they're playing each other at elite levels - if someone from outside their elite group happens upon the game then they'll get wiped out instantly by *any* of the others, same would happen if that newcomer had the best set up - but at least then they might not have those anomalous visuals of players appearing/disappearing and so on.
when i played UT on 56k modem years ago the better players were already way ahead, despite everyone being limited by the modem and few having dedicated systems for online gaming
Reply 51 of 62, by Lutsoad
gerry wrote on 2025-08-19, 08:29:
Doubt Schumacher could've won 7 titles in a Minardi. 😁
Reply 52 of 62, by BitWrangler
Lutsoad wrote on 2025-08-19, 10:37:
I have a vague memory of an F1 race, mid to late 90s... top 10 driver got let go from a top 3 team towards end of season. It may actually have been to give Michael Schumacher his start, some up and comer at the time. Anyway, he got a drive in a back of the grid team, then drove like a demon, getting up to 3rd or so from starting on the last row of grid, beating his former team. Like I said, very vague memory, but I want to say it was Alesi, let go from Ferrari for dissing their cars, and then thrashing them hollow in a Footwork Porsche.
Reply 53 of 62, by Blavius
Great thread! Thanks for the pro-gamer perspective oeswapi, its intriguing to learn young people are still getting into UT. Like the others I was under the impression it was just old diehards.
I played a ton of UT when it came out. Initially mainly on LANs and against bots, but when we got broadband in 2000, increasingly online. I didn't 'train' anything, I wasn't part of a clan, my computer wasn't spectacular, it was all casual - when I felt like it. But still, I was still comparatively good at it - I could join a random server and end up in the top 3. Sometimes I got first place, but other times there were 'pro' players in there that were just miles and miles better. In random public servers those people were rare, obviously because they were diluted by the mass of casual players. And for someone like me, the casuals make it fun. They allow me to feel like I'm lording it out, without having to take the whole ordeal too seriously. When I decided to give it a try again a couple of years back, obviously all the casuals were gone, so I lost interest real quick. No judgement, but I'm not interested to 'git gud' , I wasn't back then and I sure as hell am not now.
Reply 54 of 62, by leonardo
oeswapi's comment just basically reminds me why they invented skill-based matching for modern online multiplayer games. It's no fun if someone you're playing with is so far above you that they'll automatically win every time. UT99's weakness in modern times is that you have to match up with players yourself - and that is much more easily done in a satisfying way when everyone knows the other players, over LAN or private server.
I can identify with the OP. I'd rather have a good time playing than do all this insane tweaking and training just so I can win. Winning is fun, but all fun ain't the winning.
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 55 of 62, by Lutsoad
BitWrangler wrote on 2025-08-19, 12:28:
It happens once in a blue moon but F1 is incredibly boring because best car = GP title.
Reply 56 of 62, by jh80
made an account specifically to reply to this […]
peace
Good post, and I agree.
I'm not a competitive gamer anymore, but (among other games) I played Tribes competitively from 1999 for a number of years on a top 5 team on the base ladder (first on OGL and then on TWL). Back then, the single factor that separated "the good" from "the best" was your ping. If you had a 150+ ms ping, you really had to be skilled to compete at the highest level, and you would have to adjust your play style to accommodate your ping. If your ping was <50 ms, you had the potential to be really good. Of course, this led to all sorts of drama back then with teams trying to use this to their advantage in server selection for matches. Hardware and setup also made a big difference, but not nearly as big as ping.
Of course, ping and hardware and all that wouldn't make a difference if you hadn't invested the many hours it took to actually get good at the game. Most top players easily put thousands of hours into the game, and yeah, if you were some casual player who's just played on some pub servers for a few hours total, you weren't going to stand a chance. I bring this up because the OP mentioned the same negative experience playing Tribes back in the day. These games had massive learning curves, and the difference between the top players and newbies was huge.
Sure, modern games have use matchmaking for exactly that reason, but back in the day it wasn't as chaotic as made out to be. Most top players played on the same few servers, and they'd often be password-protected for pubbing at peak times. You'd have to go on IRC to find the password. It was an easy way to filter out casual players. For a team-based game like Tribes, it wasn't much fun to play on a server with a bunch of inexperienced players. In that case, I'd have rather played arena or duel mod.
So, yeah, people tend to overestimate how good they are at online games. The reality is that it takes a lot of practice and a very good setup.
Reply 57 of 62, by nezwick
WELL
It's been a while since I've logged onto Vogons, and it's been fun reading all the replies to my thread.
Honestly, I had NO. IDEA. people took online gaming so seriously or competitively, especially older games. I have always been, and always will be, a casual player. And the more time goes on I am realizing I'm perfectly fine with that. Oeswapi, I don't even comprehend most of the jargon you use in your post regarding ideal gaming PC setups. The last gaming PC I built myself was in 2006, and I was on a budget, but I was just excited that I could play Doom3 smoothly.
THOUSANDS of hours? No thanks.
I only wish I could play UT99 online on my Windows 98 computer to experience the unique visuals of the Voodoo 3. For now, I'll continue to plod along like the slow dinosaur that I am on my Athlon XP 1700+ and Windows 2000!
Reply 58 of 62, by DEAT
oeswapi's post is pretty much spot on - all of the posts claiming cheating is purely cope.
This is also true with the classic Doom community, both multiplayer and even with single-player maps to the point that there's a dedicated website just for some of the most challenging single-player maps out there.
(one of my maps, Honkday MAP08 is in the second highest tier of single-player maps on the bounty list of the Doomed Index)
win16.page | Twitch
Reply 59 of 62, by nezwick
DEAT wrote on 2025-11-17, 00:15:
Uh... that link you posted to the Doomed Index, I checked it out and watched a couple of videos... total insanity. Like, SO cool to watch, but also induces so much anxiety. I've never seen anything quite like that. Genius.
Me, I'm over here trying to play through original DOOM and DOOM II on Ultra-Violence for the first time in my life (keyboard only) and I'm struggling hard. Frequent saves and frequent deaths. I finally got through DOOM without cheating, but I will admit I had to noclip a couple of times in DOOM II because I Just couldn't find the last key.
