Reply 160 of 208, by Mr.Hunt
mbalmer wrote on 2025-07-23, 18:37:
You can buy the ZuluIDE with the DAC shield from several places. Check here and you can go directly to a shop based on region. I […]
Mr.Hunt wrote on 2025-07-23, 17:49:
Hello! I am very interested in zuluide, but I have a number of questions. Please tell me, where can I buy zuluide with cd dac board? And how can you make a control board, preferably with buttons not with an encoder (I hate it). And the second question is, is the firmware for PLD publicly available?
You can buy the ZuluIDE with the DAC shield from several places. Check here and you can go directly to a shop based on region. If your region isn't listed, you can order it via the eBay listing linked on the "where to buy" page.
For the control board, there's only the one design at the moment.
Assuming that by "firmware for PLD" you mean the firmware for the microcontroller, then yes, the firmware for the RP2040 microcontroller is available on the Github repo.
Unfortunately, there is no DAC in all these stores, so I asked this question here. About firmwarefor PLD, I mean non RP4020, I mean PLD which is responsible for the communication between the IDE and the PR2040
Reply 161 of 208, by mbalmer
Mr.Hunt wrote on 2025-07-23, 20:22:
Ah, I see. The DAC shield is out of stock at the moment, that's why it's not showing up. I know that we've had a bunch of hitches getting things from overseas lately thanks to tariffs and I could absolutely believe that that is the reason that we're out of them at the moment -- if the boards are hung up in customs, then we can't prep them to go out and that would also be why our overseas partners don't have them -- we finish them before sending them overseas to folks like Studio-Services.
As for the FPGA, the files to generate the core for the FPGA are not publicly available as they aren't strictly necessary to make changes or to improve upon the device emulation.
Reply 162 of 208, by Diceman63
mbalmer wrote on 2025-04-10, 07:18:
Lomdar67 wrote on 2025-04-10, 06:42:
Probably an oversight on my side, but I can't find any information what OLED display you designed this for.
Oh, oops. The OLED is a standard 0.96" 128x64 I2C module using an SSD1306; the same kind that you can find on Amazon. Here's a link to one possibility: https://www.amazon.com/Hosyond-Display-Self-L … y/dp/B09T6SJBV5
Hi there,
I tried 2 different SSD1306 based OLEDs (128x32 and 128x64) at the I2C port (I2C adress 0x3c) but none of them showed something 😀 I'm using the most actual firmware and a valid image on the SD card. Also I connected the 10k pullup resistors to the SDA and SCK lines. Is there something special to be enabled or a special kind of firmware or additional hardware needed to get the OLED running?
Best regards
Bernd
Reply 163 of 208, by Diceman63
Diceman63 wrote on 2025-07-29, 11:24:
Hi there, I tried 2 different SSD1306 based OLEDs (128x32 and 128x64) at the I2C port (I2C adress 0x3c) but none of them showed […]
Hi there,
Best regards
Bernd
I found the answer by attaching the other components of the controller schematic to the I2C port - without the PCA9554AP chip the OLED won't be recognised. Currently the SSD1306 seams to be controlled in the 128x32 pixel mode so a smaller 0,91" OLED can be used and that fits perfectly in a 3,5" case 😉
Reply 164 of 208, by mbalmer
Diceman63 wrote on 2025-07-29, 19:03:
Hi there,
Best regards
Bernd
Ah, yeah -- I was curious as to how you had things actually connected, and yes, you do need the PCA9554 on the board because it provides the I/O expansion needed to be able to interface the buttons and rotary encoder and therefore, everything, display information included, has to pass through it. Without that, the display is just getting a giant dump of I2C data that doesn't follow the format it's expecting because it's not being filtered and broken out properly. And yes, it is being sent in a 128x32 mode for exactly that reason. Depending on how things go for me here shortly (I'm actually getting ready to go back to school for a second bachelor's degree) there may be work on the interface to allow for other display types and formats but that's pretty far down the list.
Reply 165 of 208, by mbalmer
crusher wrote on 2025-07-21, 08:09:
I'm speaking of the Drive Mount mbalmer is working on. Have a look here: […]
aperezbios wrote on 2025-07-18, 17:28:
All ZuluIDE boards come pre-assembled and on a bracket. I assume you're actually wanting some sort of bundle. If so, it would be helpful to know _exactly_ what you want.
Have a look here:
Re: ZuluIDE: A proper IDE device emulator for retro PCs
Sorry for the delay in replying here. Yes, I've been working on one where there's a mount where the interface is attached directly instead of having to mount the parts of the board to it. I'm also preparing to go back to school here in a couple of weeks to get a second bachelor's degree, so a lot of my time has been sunk getting prepared for that.
Regardless, on the updated drive mount: there's been quite a bit of work done, mostly with printing iterations of it and trying to slide components around so that there aren't any collisions and the board can still be mounted cleanly -- all while trying to keep the interface board relatively small and still not interfere with the vertical height of the parts on the ZuluIDE.
That last point has been the hardest thing to navigate so far, and the tariff situation made things significantly more difficult. So, in the interest of transparency, here's a peek behind the curtain at some of the steps in the middle.
When I do an iteration of the board, I have to order prototype boards to ensure that everything actually lines up like my measurements show they should. In most cases, I would order a prototype board with most of the SMT parts already populated because not only am I testing fit, I'm also testing usability. This is a move that would not only save time, but also money because ordering the parts through JLCPCB often resulted in lower costs. With the tariff situation, that's basically turned many things on its head, and so now, I'm forced to order completely unpopulated boards, procure the parts, and do the assembly work for every prototype -- which slows things down by several orders of magnitude.
While 3D printer filament spools, even with tariffs, haven't gone up much, prototype boards absolutely have, and as such, cost overruns have ballooned out of control. As such, prototype runs with a quick turnaround have been unmanageable in terms of expense, and that's primarily where the hangup has been. I wish that situation was different, because before this, I could order a batch of prototype boards, get them here in about a week, test, adjust placements/etc, and repeat, all without too much trouble.
I have a run of boards that should be arriving here in about a week that I'm hoping will be the final iteration of it, and once that happens, I should be able to post further details.
THAT SAID, the original drive mount that incorporates the older hardware interface design is still quite serviceable if you're willing to build up the interface board yourself. It just isn't the new hotness. 🤣
Hopefully, that explains things.
Reply 166 of 208, by crusher
Thank you so much for the detailed explanation und status update.
We all have a real life and that comes first! I wish you all the best for your second bachelor study.
I'm not in a hurry and can wait until everything is of your satisfaction.
It's finished when it's finished.
Of course I wish all the best for your drive mount project, too.
Reply 167 of 208, by trunk70
IS it possible to set a static ip address for the pico2w ?
Nb : il love the zuluide with the dac and pico, everything works perfectly!
Vous devriez voir ce que je vois.
Reply 168 of 208, by old school gamer man
douglar wrote on 2025-01-16, 13:39:
Congrats. Those rubber bands in my existing drives are not getting any newer.
I never understood why people think the rubber bands in CD drives will be the death of CD drives, they are supper simple to replace, none the less this is a interesting project.
But how is this not seen as spam post to sell a product, like if anyone asked where to find something to buy or tried to sell anything here it gets removed with the disclaimer that vogons is not a marketplace yet we have a lot of people here listing parts for sale... Obliviously some favoritism or back door deals going on here.
Reply 169 of 208, by mbalmer
trunk70 wrote on 2025-08-01, 18:39:
Yes, but you'll need to set the IP address from the router side of your network setup, as the network stack in the Pico is only capable of DHCP requests.
Thanks for the note, too -- I will pass it on to the other members of the team!
Reply 170 of 208, by vetz
old school gamer man wrote on 2025-08-01, 18:48:
/Mod
Normally I'd send you a PM, but I wanted this to be public to set things straight.
Instead of saying the same non-true statement in every thread you can message the mod team if this is a real concern of you. Vogons support projects like the ZuluSCSI, even when its a product being sold. The only requirement is that the transaction itself happens outside of the forum. There is a clear distinction between homebrews and community projects and general sale and trade (as others have pointed out to you in the Sonic 8 thread)
I do not want to initiate further off-topic discussion in the thread, so any comments can be done on PM to someone in the mod-team.
Reply 171 of 208, by TgamesFR
One good thing i've noticed i share if someone got the same issue.
In case the ZuluIDE takes longuer to start when you boot your PC, and also have long times loading the list of images, it might be related to some .cue files who have the word "PREGAP" and others things in them.
At first i thought it wasn't related but as soon i've redone the dumps only with tracks and indexs in cue files the init of ZuluIDE was instant.
Even the load of the list of images in the web interfaces was instant too.
Before i had to reboot the PC once for the device to be detected by the bios (was timeout after 5 seconds of the bios trying to detect it).
And for the web interface i had to wait around 30-60 seconds for games to appears (like the ZuluIDE read images and check them one by one in a slow process).
Also i still confirm the new update (firmware + HTTP-PicoW) is broken, even the new code "Failed to open root directory" who was added always fails.
I don't have any errors in logs except "Failed to open root directory", what is noticeable it's the ZuluIDE keep fast flashing (no morse code just fast flashes) over and over during like 5 minutes until it get initialized in USB Mode.
And same thing for IDE Mode takes around 2 minutes to fully be initialized and the http access most of time answer "Not responding".
As soon it's downgraded, all of thoses gone.
Strange nobody yet got that issue.
On the previous update from 2 July all is fine (v2025.07.01 for firmware and 2025-05-09-1 for HTTP-PicoW).
I will stays on that older firmware for a while as i'm happy and everythings works.
I just share my experience if someone have the same problem, just try what i've said.
Reply 172 of 208, by Imito
quick question
i have zuluide with the DAC addon board
is that compayible with Pico 2W or only with Pico w?
im asking because now shops started to sell "pico 2W" more and the older "pico W" and harder to find
Reply 173 of 208, by aperezbios
Imito wrote on 2025-08-21, 12:35:
quick question i have zuluide with the DAC addon board […]
quick question
There is currently not a build for the Pico 2W, but we will see about generating one. Which country are you in? It would be helpful to know, as we may be able to recommend sources of the Pico W.
Reply 174 of 208, by batmreload
I'd like to get one of these, But only the V2 is listed at the moment, and the optional DAC is not available for selection.
But, from the same site, the audio DAC is listed as for sale.
Does the DAC not work with the new revision?
If not, is there an ETA on the DAC boards? Also, when will the hardware selection device, shown above, be available for purchase?
References:
https://shop.rabbitholecomputing.com/products … LcEaAukGgbRW8ut
and
https://shop.rabbitholecomputing.com/products … -zuluide-owners
Reply 175 of 208, by mbalmer
batmreload wrote on 2025-10-10, 15:17:
You’re correct, the prior DAC board doesn’t work with the new revision — the RP2350 allowed for more I/O pins to be brought out and so the pinout on the extension header changed to reflect that.
However, I’m showing that the DAC board for the V2 is available — I can select it and add it to a cart.
The attachment IMG_1069.jpeg is no longer available
The attachment IMG_1070.jpeg is no longer available
If you mean the audio DAC as a standalone item, you’re right, it’s not there. I can message the team and see if that is something they can address.
If you mean the hardware interface board, you can build one yourself — the build files for the original standalone interface can be found here, and you can use the files there to have a board house make a few of them for you if you are good with some soldering. The original interface is completely compatible with all versions of the ZuluIDE.
I made a post earlier about the process of getting the boards made that some others have already used.
I will look into making some of them available for purchase for those who don’t want to make them themselves.
Reply 176 of 208, by mbalmer
I'd like to get one of these, But only the V2 is listed at the moment, and the optional DAC is not available for selection. […]
References:
and
I almost forgot to ask -- are you inside the US or outside of it?
Reply 177 of 208, by batmreload
Thanks! Rabbit hole computing reached out to me directly and explained he updated his stock!
Yahoo! Back in stock (For the moment)
mbalmer wrote on 2025-10-10, 21:48:
References:
and
Reply 178 of 208, by TgamesFR
I confirm lastest ZuluIDE firmware fixed the issue i had since August on all new firmwares (the device was keep crashing over and over making it unusable with my images).
Now it can finally be updated and so i can try the updated HTTP PicoW part as well. Prob it was related to the issue #247 fixed by morio.
Thanks to him !
The only remaining issue i encounter is when i first start my Slot 1 Pentium 2 build from a cold boot, the ZuluIDE is not fast enough to be initialized in the bios.
Pausing the bios or doing a reboot and it's good.
I guess it's not something fixable right @mbalmer ?
Except that, everything great, ZuluIDE is a great board for DOS CD Audio gaming.
Reply 179 of 208, by mbalmer
If your Slot 1 build has a "quick boot" option in the BIOS, you can switch it off and it will extend the boot process long enough for the ZuluIDE to finish its job.
Sometimes, instead of a "quick boot" option, you'll get an "Above 1MB memory test" option instead, and in that case, turn it on instead.
Quick Boot usually skips any extended memory testing and doesn't generally probe for device changes from boot to boot unless explicitly told to. If it does test all of the memory, it's usually only one pass, and it's over pretty quickly.
The Above 1MB Memory Test is exactly what it says on the tin -- a lot of BIOSes would only test the first 1MB of memory and then skip testing the rest (it would merely count the rest, usually by toggling all of the address lines sequentially and seeing where changes are to determine where the "end" of memory was).
Considering the age of a lot of our retro equipment, forcing the board to run the full suite of POST tests instead of a quick version is usually a good idea, IMO. Another option that's sometimes present is to increase the timeout value on the BIOS's scan of the IDE bus, but that option isn't present in all BIOSes.
TgamesFR wrote on 2025-10-30, 06:27:
I confirm lastest ZuluIDE firmware fixed the issue i had since August on all new firmwares (the device was keep crashing over an […]
Thanks to him !
