Reply 30000 of 31937, by PD2JK
Polished up these two 550 MHz / 2MB workhorses:
The attachment DSC_5717.JPG is no longer available
The old cooling paste looked more like dried up toothpaste and it was quite tedious to get off. Alcohol, white spirit and sticker remover did the trick eventually.
has all kinds of stuff
Reply 30001 of 31937, by dominusprog
StriderTR wrote on 2025-08-15, 02:40:
Got it. So is it necessary for the wavetable to function? Or it can work as any other wavetable?
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 30002 of 31937, by StriderTR
dominusprog wrote on 2025-08-15, 19:47:
I don't believe so, at least not in this case. I mean, you need a DAC somewhere to convert the emulated digital output from the Pi Zero into an analog output the card can send to your speakers. Though, I could be mistaken.
On here, the 3.5MM jack isn't used. The DAC does the conversion and sends it right out to the wavetable header.
Pi Zero GPIO21 to the DIN (Digital Input) on DAC, then to the DAC Analog L&R outputs, then to Wavetable Header Pins 20 & 24 through a couple 10uf caps.
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
Reply 30003 of 31937, by douglar
I redid some old fragile battery fixes with sturdier "Not-a-varta" setups.
$20 for 50 PCBS, $20 for 20 SOT-23-5 hot exchange voltage controllers. That should keep me set for a while--
My First PCB Way order 0 the parts are so tiny, going to need the big magnifier to solder these....
The attachment Photo Aug 16 2025, 2 24 18 PM.jpg is no longer available
Sturdier Solutions #1 You can see where I burned the board before.
The attachment Photo Aug 16 2025, 2 24 58 PM.jpg is no longer available
Sturdier Solutions #2 I feel like I am not embarrassed by this board any more
The attachment Photo Aug 16 2025, 2 25 40 PM.jpg is no longer available
Reply 30004 of 31937, by pan069
I did some (de)soldering yesterday for the first time in many many years (like, thirty or so). A while ago I found an old motherboard in the garbage while on my daily walk. It had blown capacitors and I thought this might be a good opportunity to do some soldering. I had been gathering bits and pieces of equipment for a while now, like the iron [1], and yesterday was the day.
I live an apartment so I don't have a lot of space, so after I set up my gear I took a shot. Long story short, I started with the caps nearest the CPU as they were bulging the most. I took a while to get the hang of it (my eyes also aren't great as I have issues with depth perception due to a congenital cataract in my right eye). It took a while to get some movement of the first pin. I added some flux, that showed me that at least heat was being transferred.
Some issues I ran across:
1 - When I tried adding some solder to the pin I realized that I have bought shit solder as it didn't stick or flow very well, it often kinda turned into small balls or "crumbly towers".
2 - The solder wick I purchased also didn't seem to work well as it didn't seem to absorb solder. Maybe my iron just isn't powerful enough because placing the wick between the pin and iron, not much happens, even at 420c .
3 - In the end I managed to remove 6 caps, after the first two it became easier, the caps get quite hot as I have my thumb on it that I use to put some gentle pressure on it while heating up a pin. But now all the holes are closed and due to the shitty solder and wick, adding solder to clear the hole doesn't work. I might have to get a solder sucker for this after all. I have no room for a desoldering station.
Anyhow. I'll try to get some better solder. Any recommendations? I am in Australia so not everything might be as available as elsewhere in the world.
[1] https://www.fnirsi.com/products/hs-01?variant=45534131618010
Reply 30005 of 31937, by H3nrik V!
Started unboxing and taking inventory of my huge stash from AVICC, which I had sent to my hotel when visiting Chicago earlier this week. If memory serves me right, there's 115 miscellaneous CPUs, 2 motherboards, at least one graphics card and some keychains too 😎
Reply 30006 of 31937, by riplin
pan069 wrote on 2025-08-16, 20:22:
I did some (de)soldering yesterday for the first time in many many years (like, thirty or so). A while ago I found an old mother […]
Flux is your friend. If in doubt, add more flux. You can never add too much flux. Did I mention flux? Add flux. 😀
Reply 30007 of 31937, by zuldan
I’ve been through many soldering stations. I wish started with this one and saved myself the money https://www.aliexpress.com/item/1005005820847973.html (choose T3A T245 Set B). It will handle anything you throw at it. Plus the auto switch off when the iron is placed in the holder is great. You’ll want to use some low melt solder https://www.aliexpress.com/item/1005009408608556.html with some flux https://www.aliexpress.com/item/32919126582.html when desoldering those caps. I apply heat to one leg at a time and then pull each side of the capacitor out bit by bit in a rocking motion. They should come out pretty easily without the capacity getting too hot to touch. As for solder I use this https://mektronics.com.au/products/multicore- … c-0-35mm-0-25kg and this https://mektronics.com.au/products/multicore- … 2-0-91mm-0-25kg. It’s more expensive than Aliexpress stuff but it’s high quality.
When using solder wick apply some flux to top of it but a good soldering iron with a tip that has a large surface area is key.
Reply 30008 of 31937, by luckybob
riplin wrote on 2025-08-16, 20:55:
It's actually a fun drinking game. anytime you're watching a repair video and someone says flux, you take a shot. Butt seriously, you dont REALLY need much additional flux if its included in the solder, at least for thru-hole. if your doing SMD, you want to use the stuff like you're selling stock in the company...
I get my solder and wick from Aliexpress/temu. they will short change you, when you buy 100G that includes the weight of the spool, so plan accordingly. If I need something GOOD for preservation/restoration, i usually get some of the MG chemical stuff from Mouser. (i'm always ordering other parts so it just get tossed in the cart as needed)
Reply 30009 of 31937, by StriderTR
This statement is fact! 😀
Been repairing electronics for over 35 years now. Flux flows freely in my work.
I often chuckle when I see people post on YT repair videos that the uploader is using too much flux... NO SUCH THING! 🤣
Reply 30010 of 31937, by dominusprog
StriderTR wrote on 2025-08-16, 06:24:
I don't believe so, at least not in this case. I mean, you need a DAC somewhere to convert the emulated digital output from the […]
Oh, okay. I always thought that the wavetable sends a digital signal to the sound card.
Reply 30011 of 31937, by StriderTR
dominusprog wrote on 2025-08-16, 22:48:
Actually... I stand corrected.
It will work without the DAC. It's labeled as "Optional but highly recommended".
It currently supports two modes of audio: using the raspberry pi's PWM audio out (which is noisy and sounds pretty bad), and an external Hi-Fi PCM5102A based DAC.
It seems the DAC is there for a higher quality audio output, better than straight PWM output on the Pi.
Edit: Forgot to add ... The current board version, 0.3 (the ones I ordered), added a low-pass filter to clean up PWN output should you chose to not use a DAC.
Reply 30012 of 31937, by StriderTR
On a side note... it's done!
Might be a few days before I have time to play with it, but, it's assembled and setup. 😀
Reply 30013 of 31937, by Nexxen
I tested some Zip 750 disks.
Out of 5 only 1 works. The other ones have reading issues, like it could not access some track where info is stored.
The one working isn't really good, can r/w but needs old systems to read correctly (i.e. copying back).
IDK know if the 750 units where bad or the disks are plain garbage. 100 and 250 do ok though and unless they already have problems (lots of errors) they do just fine.
LS-120 performs way better.
Why did they sell such shyt? 🤣 And xhy am I buying it???
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 30014 of 31937, by BitWrangler
Nexxen wrote on 2025-08-21, 14:42:
Well the algia bit of nostalgia means pain, maybe you're just a masochist 🤣
Reply 30015 of 31937, by Nexxen
BitWrangler wrote on 2025-08-21, 15:05:
If I match the criteria here... makes this a forum of masochists 🤣
I should go into politics, I would yield as chief whip.
Reply 30016 of 31937, by Kahenraz
StriderTR wrote on 2025-08-16, 22:09:
This statement is fact! :) […]
I always use a Luis Rossman amount of flux whenever I do soldering work and it's never failed me.
Reply 30017 of 31937, by BitWrangler
That reminds me, I was gonna pick up some waders and a PFD so I can try doing it that way.
Reply 30018 of 31937, by StriderTR
My DOS 6.22 system now has a PicoGUS 2.0 with a working Wavetable Pi!
Just need to print the front panel bezel for the LCD. 😀
I find it somewhat amazing that this Pi Zero 2W powered MT-32 emulator is "more powerful" than the entire system it's running in. How far we've come, how we can re-create classic hardware, use emulation, and all of these things today with relative ease. Very cool to a geek like me.
Reply 30019 of 31937, by Nexxen
I tested an ISA SB 16 that came with a pc I bought.
I removed the AWE32 I had inside and realized it has 2 SIMM slots... Gonna try with 2MB.
Thankfully a lot of people already dealt with it 😀
