First post, by archaic_fox
MY MACHINE:
WINDERS XP PRO X64  SP2
DOSBOX VERSION 0.72
VIDEO CARD: NVIDIA QUADRO FX 550
MONITOR: CORNEA MP704 LCD
2 (DUAL) INTEL XEON 5160@3GHZ PROCESSORS
4GB RAM
MY PROBLEM: I'm running an archaic version of FoxPro in the DOS emulator. Whenever I try to go fullscreen with the Fox window, I get the message that the '85Hz refresh rate is not recommended, switch to 60Hz'. Thing is, my settings ARE at 60 Hz! So I'm thinking that perhaps it's some setting in my DOSbox... maybe something I can correct with the autoexec/.conf file? I HAVE READ THE README a dozen times, maybe I'm missing it... Can you help?
Thanks in advance,
Archaic Fox
