First post, by Bigbernie59
Hello
With a single old MSDOS game using only a frontend like Utopia Box or DFend, so with BOTH I always get a Windows 11 crash with a Display "Out of Range" error message and it tells me I have to change the game to 1920x1080. Which is impossible.
It's Dosbox that forces the Windows screen to adapt to its 1985 display, not my display, which I have to modify to switch to 4 colors. My frontends work perfectly with all old DOS games EXCEPT CIV One.
CIV 1 with Dosbox is fine. Civ 1 with Utopia or DFend frontends and I get Out of Range immediately.
How can I fix this?
Thank you very much.
Reply 1 of 2, by rico001
Bigbernie59 wrote on 2025-08-20, 19:53:
Hello With a single old MSDOS game using only a frontend like Utopia Box or DFend, so with BOTH I always get a Windows 11 cras […]
Hello
How can I fix this?
have you tried 1. DOS file managers, examples: x-tree gold,y tree... 2. Curious what type of display does this?
Reply 2 of 2, by wierd_w
Dosbox lets you define the fullscreen resolution.
It does not have to be 'native'.
Re: Full screen configuration
Lists the directives you can use to control this.
You can force it to be anything.
