gmaverick2k wrote on 2025-08-22, 21:39:
theelf wrote on 2025-08-22, 21:15:
theelf wrote on 2025-08-15, 23:49:Hi guys need some advice, i have a picogus, PC 286, usb mode, only one cue/bin (megarace) in pendrive, load cdrom driver […]
Hi guys need some advice, i have a picogus, PC 286, usb mode, only one cue/bin (megarace) in pendrive, load cdrom driver cdmke.sys OK, assign unit ok, if I run pgusinit.exe even say megarace.cue is loaded
The attachment 1.jpg is no longer available
But if i do cdlist or cdload i get a timeout
The attachment 20250816_010154.jpg is no longer available
The attachment 20250816_010011.jpg is no longer available
I tried different cue/bin and ISO images and pendrives, 512mb, 1GB, 4 and 8GB, multiple brands, all FAT32, same problem.
Im out of ideas! thanks for any help
Any idea guys? i tested like 20 pendrives, SD>USB cards, CF>USB cards, whetever USB can be formated to FAT32 i have in home... all same
I had that issue show up for me too. Old usb2 sticks showed that but an SSD in a usb3 caddy is fine. Try updating picogus inside dos, initially I did it externally using usb cable. Secondly use the picogus solely in usb mode and not in sb mode, important. I have it paired with an ess 1868f + x2gs
Hi thanks for reply, sorry delay, i was woking outside home and I did not have my computer with picgus this days
I update picogus inside DOS, in fact never update from usb in a modern PC and use in USB mode only, but problem remain
I tried different SSD in USB case, i tried IDE HDD in USB case, i even tried a CF card in a USB reader, NOTHING, every single time give me the timeout
I tried firmware 3.0, 3.1, 3.2...
I believe was my 286, but i tested the picogus card in a 386, a cyrix 5x86 and a Pentium 200, same problem, exactly. Beside this, the card work in anything, GUS, tandy, MPU etc
But what i really need is CDROM emulation...
