First post, by douglar
So looking back at things that bothered me back in the day, the first was "Why doesn't this VLB controller make any difference" I'm not done with that, but let's say I've explored that a little bit.
The second was "Why does my new s3 Virge card do nothing special except run these 2 lame demo games?" That one answered itself in do time.
The third was "Why is this MVP3 motherboard pure torture with AGP?"
Seemed like time to explore that so I went to the cupboard and pulled out a https://theretroweb.com/motherboards/s/dfi-p5bv3-e-rev-b
I left it configured with a K6-III 400 and a 256MB DIMM a couple years back. Boots up. Mounts the 8GB CF with UDMA. I start the scripted windows 98 install. Completes. Installed the 4-in-1. Installed video driver. Crash. Reboot. Crash. Safe mode. Uninstall stuff. Crash. Crash. Reinstall in new directory. Crash. Crash. Tweak and hack up the registry. Crash. Crash. Maybe it's working? ......... Crash. The crashes are a mix of GPF errors and memory looking errors.
I pulled out a https://theretroweb.com/motherboards/s/fic-va-503, added a 500Mhz K6-2+, jumpered it up, turned on the power, no post codes. Caps look fine. Double check jumpers. no post codes. It goes back in the cupboard. I probably need to go back to an old CPU and update the BIOS and try again some day.
Back to the DFI board.
Memtest time! I get memory errors after an hour. 256MB Dim goes back in the static bag. New (for me) 32MB dimm goes on the board. Runs mem test for a hour without errors. Back to the windows install. Fail. Freeze. Reboots. Back to memtest and I let it run for a while. No errors, but it does lock up after 2-3 hours. I go back to the BIOS and set the memory test as loose as possible. Memtest all night. 40 passes. No locks, no reboots, no errors. OK!
Back to starting the scripted install. Errors out, but I was reinstalling over the failed & butchered previous install. I delete all the files except for my scripted install directory and restarted it. It's reached the first reboot point with no errors yet, but I'm not optimistic.
Sigh. As the half life G-man once said: "Well, well, isn't this just like old times"
p.s. Interestingly, after reading the "VERY IMPORTANT NOTICE" on https://theretroweb.com/motherboards/s/fic-va-503 , I can see a possible reason why my 1999 system with a TNT2 gave me so many headaches.
Reply 1 of 11, by douglar
So that last installed failed. After the reboot during the install, I got an "ODBC Installer DLL is not installed on this system" and after the next reboot I got registry corruption errors.
I deleted the files off the drive, copied over fresh scripted install files from a contemporary computer, did an error check on the SD, turned off UDMA in the BIOS, and then restarted the scripted install.
The install stopped here with the mouse still working but the keyboard num lock unresponsive:
The attachment Photo Aug 23 2025, 11 29 02 AM.jpg is no longer available
Reply 2 of 11, by bertrammatrix
douglar wrote on 2025-08-23, 15:12:
So that last installed failed. After the reboot during the install, I got an "ODBC Installer DLL is not installed on this syste […]
For any motherboard that has symptoms like this that seem to be memory related that has onboard level 2 cache - try slowing it down or entirely disabling it in bios and see if the problem goes away, or if it makes no difference
Reply 3 of 11, by douglar
bertrammatrix wrote on 2025-08-23, 19:03:
Disabling the external cache fix things, thanks!
Reply 4 of 11, by bertrammatrix
douglar wrote on Yesterday, 14:49:
Ok, well that's not really a fix but good to hear it at least made a difference. Performance will likely be pathetic without it. You could try cleaning the board around the cache, or if that doesn't help you could try cooling it with a little heatsink on it, or a fan.
Sometimes these chips were already borderline adequate for the upper FSB speeds SS7 boards could do when they were new, 30 years later the situation is obviously only worse. It may still work fine at 66, 75 or 83 but not be able to do 100 reliably
Edit - since you are using this motherboard with a k6-3 that has it's own L2 cache and effectively uses the motherboard cache as L3 - I wonder if the penalty for disabling the motherboard cache may be fairly minimal
Reply 5 of 11, by douglar
bertrammatrix wrote on Yesterday, 15:21:
There's a hit, but it's < 10%. It isn't a deal breaker. I was running the 03/08/1999 BIOS. It is supposed to know about the K6-III, but I see 01/03/2000 rev A is newer. I'll give that a shot.
Reply 6 of 11, by douglar
douglar wrote on Yesterday, 20:42:
Here's how it went:
  1. I installed the new bios which returned settings to the default values, including external cache = enabled
  2. the system rebooted and installed a couple new drivers
  3. before I could restart, the registry got corrupted beyond repair
  4. I'm back to reinstalling Windows 98se
The attachment download.jpg is no longer available
Reply 7 of 11, by bertrammatrix
douglar wrote on Yesterday, 23:50:
Here's how it went: […]
Here's how it went:
Haha, yup, typical results 😀 that's the best when it looks really promising before repeat fubar 😀 well at least now you know
Reply 8 of 11, by douglar
So after reinstalling windows I was still having trouble. I wouldn’t get a windows desktop, just a black screen in text mode. I noticed that after the crashes, the CF was unresponsive until a power cycle. The Bios upgrade had reenabled udma for the device. Turning off udma and forcing pio4 seems to have fixed that issue.
Reply 9 of 11, by douglar
OK, I'm remembering why these super 7 boards are so addictive. Because you think you can fix them if you just do a little more work !!
Here's some speedsys benchmarks:
1) No cache / loosest memory timings. SDRAM = SLOW / CAS 3.
The attachment TIMING_result.png is no longer available
2) Cache Disabled - Memory throughput increases from 152MB/s to 168MB/s. SDRAM = Turbo / CAS 2.
The attachment NOCACHE_result.png is no longer available
3) Cache Enabled -- No change to the CPU score. Everything must fit in the on chip cache. SDRAM = Turbo / CAS 2.
The attachment CACHE_result.png is no longer available
4) Using Sandisk Ultra CF instead of Innodisk iCF 4000. SDRAM = Fast / CAS 3.
* Curiously, the CPU benchmark takes a hit with the Sandisk. That wasn't a one off. It was completely repeatable and it was the same regardless of the main memory timing.
* Sandisk didn't perform as well in Dos, but it wasn't really noticeable
The attachment SANDISKG_result.png is no longer available
5) The Sandisk doesn't have the UDMA issues.
* Operations < 8kb are slower, Operations > 8kb are faster
* The general feel of windows 98 is better. Fewer pauses. Fewer crashes.
The attachment att_san.png is no longer available
Reply 10 of 11, by douglar
Mother-fudgecicles! The board isn't seeing IDE devices anymore. This is definitely a toxic relationship.
Reply 11 of 11, by Intel486dx33
One of my first computer builds was a AMD k6-2 ( 300mhz ) from what I remembers.
I was running Win95/98
It did not run very good because I was new at building computers and was just learning.
I think i may have had the jumpers set wrong and I was using the wrong type of ram too.
So it would crash everybody now and then.
I was going to get around to fixing it but I really wanted a BX440 motherboard with Pentium ll-400
So I put away the K6 and Built the BX440 instead.
That is when I decided to only use intel CPUs and I never went back.
Until, I got into retro computers I wanted to rebuild that AMD K6 computer so I didn’t.
It works okay with all the right settings and ram but I still think the Pentium computer is more stable and reliable .
I install Win98se
Then SP3 core updates only
Reboot
Then install Directx 9 from SP3 package
Reboot
And then install voodoo and Sound card software and drivers
Works pretty good.
Stable and Reliable.
Wish I knew this back in 1998
Would’ve have saved me allot of frustration
