I/O Plate
First post, by DustyShinigami
Hi
After the issues with the previous ATX case I had, which I had no choice but to get rid of and get a new (old) one. Thankfully I won it for a decent price. I now finally have one that has connected LED and power/reset cables how they should be. Plus, this one is much bigger with additional bays for CD drives, floppy drives and the three HDD drives I need. It even has a PSU with it and additional fans for extra cooling. 😀
However, one thing that is missing is the I/O backplate. The question is, how would I best tackle this problem? Because I'm guessing, as usual, there isn't a one size fits all. This motherboard - https://theretroweb.com/motherboards/s/abit-ab-be6-ii - doesn't have that many ports/connectors, to be honest.
The attachment IMG_4482.JPG is no longer available
Sadly, this ATX case is completely unknown. There's no name brand or any indication about who made it.
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 1 of 19, by Yoghoo
If you have a 3D printer you can design and print one. Did that many times in the past. There are also a lot of pre designed models available on Thingiverse, Printables etc.
Else you can look at Aliexpress or so for a closed one and cut the holes yourself. Or try one from another motherboard.
Reply 2 of 19, by CharlieFoxtrot
Many backplates from roughly the same era fit with several motherboards. I have used same IO plate with different motherboards.
If you can access 3D printer, that is one way. You can find designs in printables or thingiverse. There are some that are designed specifically for certain MB, but then there are blanks and meshes, where you can cut or CAD your own holes.
Reply 4 of 19, by The Serpent Rider
This is a standard ATX layout which all early ATX motherboards were shipped with, so any standard plate will work.
Reply 5 of 19, by Major Jackyl
If you go the 3D print route, I have this one in my collection:
The attachment ABIT-BE6.PNG is no longer available
The attachment ABIT_BE6.zip is no longer available
I've been lining the backs with foil tape lately and it makes them feel more realistic (and actually shield).
Shponglefan wrote on 2025-08-24, 19:25:
I buy spare backplates from Ebay. You just need to find one that matches the layout of the motherboard components. Most of them are pretty standard.
These are indeed some of the most common backplate, not too hard to spot, even in a large pile.
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 6 of 19, by DustyShinigami
Thanks for the suggestions everyone. Sadly, I don't have access to a 3D printer. Yet. It is something I'm interested in though as I do character modelling and sculpting. If it is fairly standard and easy to find, that's good. Reassuring. I'll take a look on eBay and AliExpress and see what I can find. 😀
OS: Windows 98 SE
Reply 7 of 19, by DustyShinigami
Hmm. Can't say I've been having a lot of luck finding one. Most that come up have a lot of holes for the various ports/jacks. Finding one for this specific model, which only has seven, is proving tricky.
OS: Windows 98 SE
Reply 8 of 19, by PC Hoarder Patrol
DustyShinigami wrote on 2025-08-25, 16:36:
This one?... https://www.ebay.co.uk/itm/126713871485 (not my listing)
Reply 9 of 19, by DustyShinigami
PC Hoarder Patrol wrote on 2025-08-25, 17:22:
You utter legend! Thank you. 😁
I guess my searches were too specific. I was typing in the motherboard model followed by I/O plate. Or Abit I/O plate. :p Less is more, I guess.
OS: Windows 98 SE
Reply 10 of 19, by DustyShinigami
Only snag though, is that first image doesn't appear to be assigned to any particular model. Going through the ones that are available in the drop-down list, they're all the wrong ones. So I'm wondering if that first image is to a model that's sold out. I'll try reaching out to the seller.
OS: Windows 98 SE
Reply 12 of 19, by DustyShinigami
maxtherabbit wrote on 2025-08-25, 18:41:
bit expensive but what about this one
https://www.ebay.co.uk/itm/157143746603
Ooh. Nice find. Thanks. Yeah, it is a bit pricey for what it is. I'll see if I get a response from the other seller first, but if not...
OS: Windows 98 SE
Reply 13 of 19, by DustyShinigami
Okay, so I finally got around to getting a replacement plate, however, as is the case with me, I'm easily confused and struggle with the most basic of tasks. ^^; I got a similar plate to the ones linked, but paid much less. However, I'm struggling to fit the damn thing. Newer machines seem to have them inserted from the inside of the case so they're facing out. I get the impression with this setup, that they're inserted outside of the case. However, the left side doesn't appear to line up and I can't get it to snap into place. The right side I can. I'm starting to wonder if this case needs a very specific I/O plate...?
The attachment IMG_5512.JPG is no longer available
The attachment IMG_5515.JPG is no longer available
The attachment IMG_5516.JPG is no longer available
The attachment IMG_5517.JPG is no longer available
OS: Windows 98 SE
Reply 14 of 19, by Errius
If you're sure it's the right size you can use a small hammer to force it into place. It's what I do when the fit is difficult.
However that looks like it came out of an OEM system. Why didn't you just buy a plain metal generic plate instead of that? Those fit everywhere.
ETA: I see it has part number 5065-6701 which almost certainly is HP. (I have HP stuff with similar numbers, e.g. Netserver LH-4 I/O board is 5064-7070.) HP are notorious for using non-standard stuff in their computers.
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Reply 15 of 19, by Shponglefan
DustyShinigami wrote on 2026-05-13, 15:50:
That looks like it should be inserted from the inside of the case, not the outside.
Remove everything from the case and then try to install it from the inside.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 16 of 19, by Errius
I've never seen an I/O plate that is fitted from the outside. It sounds like bad design because it will just pop out if the case is flexed.
Reply 17 of 19, by DustyShinigami
Errius wrote on 2026-05-13, 21:40:
Ah. Bugger. 😕 I figured it would be one size fits all if it had the same number of port holes. Not to mention the ones I was originally linked to are quite pricey for what they are.
OS: Windows 98 SE
Reply 18 of 19, by DustyShinigami
Shponglefan wrote on 2026-05-13, 21:50:
Okay. I must admit, I really couldn’t be bothered getting everything out to insert it, but if that’s what’s required. 😅
OS: Windows 98 SE
