Reply 57380 of 58627, by CharlieFoxtrot
Mandrew wrote on 2025-08-26, 08:43:
This one was originally paired with the Tulip AT compact and that shipped with both the MDA and the CGA option. I've yet to see a MDA card with a 6DIN connector but this has the original 6DIN-9pin cable included.
CharlieFoxtrot wrote on 2025-08-26, 08:29:
Why did they use other type of connector? Most likely those monitors were also sold for other applications, such as bundled with some terminal
Good explanation, the same chassis was probably sold to multiple manufacturers based on application and the 6DIN connector was cost effective.
Yes, I saw that it was Tulip branded tube, but it is pretty much certain that it isn’t manufactured by them. As an european computer brand I can almost bet that the monitor is manufactured by Philips and nearly identical to what I disucssed, at best with some slight modifications in addition to the different badge. If I remember correctly, some of those Philips monitors had a fixed cable with 6-pin connector, but monitor was supplied with an adapter for PC-standard 9-pin. It is a simple and cheap solution when the monitor uses correct signaling, just a rewire.
The monitor was probably originally aimed towards some specific application, maybe a Philips made terminal or something. For other purposes they just supplied an adapter or specific cable as that doesn’t require any big changes in the chassis assembly line. So yes, cost optimization is the reason for this type of stuff, as it is pretty much always with choices regarding large scale manufacturing.
Reply 57381 of 58627, by vutt
Today's loot secured on local auction saite.
Audigy 2ZS was dirt cheap, but with AWE64 Gold there is always 1 fellow collector even on obscure local sites so I had to stand my ground in bidding war. Still way below ebay prices.
I have my original Audigy card I bought back in days so bracket is not an issue. However with AWE64 Gold sourcing separate original bracket may cost me arm and leg.
Probably need to 3D print it...
Reply 57382 of 58627, by PD2JK
Good catch.
Though I can't stand cards of any kind being sold without their bracket. Is it really worth taking it off for, let's say, a scrapper?
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 57383 of 58627, by justin1985
I picked up this Advantech PCM-5825 PC104 type single board computer used from China when I realised the NS Geode GX-1 is actually a Cyrix MediaGX, and therefore has great DOS and Win9x compatibility.
The attachment IMG20250826211221.jpg is no longer available
What is this format actually called? The manual seems to just refer to it as 3.5" drive size, which makes finding anything online next to impossible! Sure I've seen it referred to as "Biscuit" too? There is a PC/104 connector, but the format is longer?
To begin with I thought it was filthy with oil or something, but it seems like the whole board might have been covered in a kind of lacquer that has yellowed?
Only tested as far as BIOS and booting into DOS from a CF card - seems to work fine though!
Most of the connectors are 2mm pitch pins, and it came without the matching cables that break out to normal sized connectors. I can't imagine crimping 34 pins of a 2mm Dupont connector onto the end of a floppy cable will be much fun ...
The Chips&Technology M6900 graphics chip seems an odd choice - doesn't the MediaGX have integrated graphics?
Reply 57384 of 58627, by pan069
PD2JK wrote on 2025-08-26, 19:16:
Good catch.
Also interesting that this scrapper decided to put the bracket retention screw/bolt back on the AWE64 card. 🤔
Reply 57385 of 58627, by vutt
pan069 wrote on 2025-08-26, 21:32:
Good catch.
Here is your explanation 😀
Reply 57386 of 58627, by pan069
vutt wrote on 2025-08-27, 06:40:
Good catch.
In true scrapper fashion. 😀
Reply 57387 of 58627, by BitWrangler
No, no, must have been one of the more careful ones... no teeth marks 😁
Reply 57388 of 58627, by mtest001
When I saw that on an auction site I could not resist... It is mine now and I'll be the coolest boomer in the open-space, at least according to me.
The attachment 3dfx-tasse.jpeg is no longer available
/me love my P200MMX@225 Mhz + Voodoo Banshee + SB32 PnP + Sound Canvas SC-55ST = unlimited joy !
Reply 57389 of 58627, by Turbo ->
Good catch.
At least the card survived. She is a beauty.
Reply 57390 of 58627, by Xicor
Hi everyone,
Just received a pinnacle themed bundle, 2x pinnacle callisto rev 7.0 and a MovieBox USB (no psu, an it takes a 3.3v input.... hope it didn't received an over voltage ....). I already had one lonely breakout snake in my collection for the callisto card, so now I have 2 sets. The matrox breakout snake is also a good find, because I do have one matrox RT.X100 that was missing it. all for the low price of 10€.
The attachment Pinnacle_bundle.jpg is no longer available
Next, a 486 motherboard from Expertboard, the EXP8449 Rev1.0. Sold as is, with an issue on the cpu socket lever. Everything else seems good, no shorts, no leaking battery, no scratched traces.
The attachment EXP8449_rev1.0.jpg is no longer available
Reply 57391 of 58627, by mtest001
A 486 board with PCI slots, I wonder who might have bought this back then...
Reply 57392 of 58627, by dominusprog
mtest001 wrote on 2025-08-28, 11:38:
People who wanted to access the PCI slots. Besides, not all ISA only boards supports 3.3V CPUs, but every board with PCI slots support the 3.3V CPUs.
Reply 57393 of 58627, by H3nrik V!
There were a lot, actually, back when the AMD 5x86-133 was a budget alternative to a Pentium PC
Reply 57394 of 58627, by BitWrangler
dominusprog wrote on 2025-08-28, 11:56:
PCI was around a couple of years before it took off, and there are P5 Pentium classic, 60 and 66Mhz boards with 5V PCI 1.0 so there may be a board or two around that are PCI 1.0 5V for 486 and officially max out with a DX2.... if an AT format board, they are probably recognisable by lack of onboard I/O, which is another pain in the butt about early PCI, since PCI multi i/o cards were super hard to find in 1995, never mind now.
Edit: Here is an example, socket 2, no 3.3V regulator in sight... https://theretroweb.com/motherboards/s/tekram-g486ip
Reply 57395 of 58627, by AGP4LIfe?
I am now the proud owner of a 1950XT AGP, one of the last 3 cards I need for my collection.
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 57396 of 58627, by Locutus
First ISA/EISA in my 'collection' 😉
Reply 57397 of 58627, by nfraser01
PCI spec relesed in 1992, pentium didn't come out until 1993 so possibly quite a few people 😀
I have a Gateway 486 DX2 system to restore that has PCI slots..
Reply 57399 of 58627, by pentiumspeed
Bought Magewell Pro Capture AIO Video Capture Card. This is one that can capture VGA, audio on a PCIe card.
Hope this works well for vintage computer capturing. Will plan on getting another capture card made by Datapath Pro VGA, the true VGA capture card.
I have a ivy bridge 8 core HP Z420 workstation. Also got the SAS controller, 1.92TB SAS SSD to try out. Need to put these together.
Two Samsung SATA 100GB SATA SSDs, in silver 15mm height. As opposed to standard 9.5mm height in typical black.
Cheers,
Great Northern aka Canada.
