First post, by theelf
Hello! I had forgot my old 286 25mhz from my childhood in warehouse for some years, and now I decide to put it to work again.
Most parts are still original from that time, and that make me very happy. The case, motherboard, I/O, video card, floppy drives, cdrom and ram is original! almost all
Now testing software, one thing im discovering is how little care many companys put on testing in 286 — many games that say on the readme 'need at least 286' just crash cause they forgot some random 386 instruction inside the code. lazy!!
Thats when the 386 emulator, emu386, save the day! Im testing games and softwares, and slowly I will make a list of all this programs and put notes on each
Any sugestions or adds are more than welcome!!
My 286:
Harris 286 25mhz
Zida TD60C board (no ems or umb sadly)
5mb ram 60ns
2GB primary FAT16 + 16GB FAT32 secondary CF card
8x Matsushita CD
AWE64
PicoGUS (tandy + GUS)
PCDOS 7.1
Ok, games + software im testing for now with emu386 and run at good speed
Three Sisters’ Story - Need a 386, but works fine, slowdown in some effects that use 386 instructions, but not ingame
Season of the Sakura - same as Three Sisters’ Story
Runaway City - same as Three Sisters’ Story
Megarace - Its clear NOT need a 386, works great. Even in setup they ask to chose if you have a 286 or a 386...
From American Lasergames... exept Mad Dog 1 that run in 286, with the others they screw it up
Mad Dog II: The Lost Gold - Funny thing in game box say need 386, in readme 286. But hangs. Another game that not need a 386, but they forgot something 386 in code. Works GREAT
Who Shot Johnny Rock? - they forgot something 386 in code. Works GREAT
Space Pirates - they forgot something 386 in code. Works GREAT
Crime Patrol - they forgot something 386 in code. Works GREAT
Crime Patrol 2: Drug Wars - they forgot something 386 in code. Works GREAT
The Last Bounty Hunter - they forgot something 386 in code. Works GREAT
realms of chaos works fine, some slowdown with audio, but very playable
Fatal Fumes work fine, little slow, playable, need a co-processor, use this emulator https://forum.vcfed.org/index.php?threads/em8 … ry-in-it.41463/
Reply 1 of 5, by DEAT
theelf wrote on 2025-08-24, 18:33:
There are at least four games that I know of where the earliest version works on a 286 but later versions require a 386 - Aces of the Pacific and Space Hulk are commercial examples, AstroFire and Blake Stone: Aliens of Gold are shareware examples. The beta of Realms of Chaos runs on a 286 properly but the released version hangs on an illegal instruction.
Additionally, there's two games I'm aware of where they are normally executed via a BAT file which include an intro EXE that requires a 386, but the main EXE will run on a 286 - Entity and The Machines.
Finally, there's another two games that will run on a 286 but Sound Blaster support requires 386 instructions - Fatal Fumes and Tiahuanaco.
I have the following games marked as "may work on a 286 with specific settings", as they all hang trying to get in-game:
Aleshar: World of Ice
Cannon Fodder
Highway Fighter/Highway Hunter
Might & Magic 4&5: World of Xeen
Might & Magic: Swords of Xeen
Realms of Arkania 2: Star Trail
Star Wars: Tie Fighter
Aleshar specifically appears to require more than 4MB of RAM.
win16.page | Twitch
Reply 2 of 5, by Jo22
Hi there! The Japanese font utility Dos-J Plus uses 80386 real-mode instructions and works with emu386.
Of course, there are likely more utilities like this that may not need it. It just came to mind.
_
The native operating system MS-DOS 6.20/V also works on an 80286,
but relies on EMM386 to succesfully manage to squeeze all these Japanese extra software into memory.
Without a 386 processor, the user would need to have an EMS card and UMB card or an intelligent 80286 chipset.
Reply 3 of 5, by theelf
DEAT wrote on 2025-08-26, 07:58:
There are at least four games that I know of where the earliest version works on a 286 but later versions require a 386 - Aces o […]
Cannon Fodder
Thanks a lot for help, I tested games you say
realms of chaos - work fine, i think they use 386 instructions to sound, because is very smoth until some sound happen and get a little slow, but playable
Aleshar: World of Ice work fine but too slow to be playable
Cannon Fodder start, but hang with a failed 386 opcode, need more testing or different versions of game
Realms of Arkania 2: Star Trail failed 386 opcode
Star Wars: Tie Fighter need EMS but sadly i dont have ems card i cant test
Fatal Fumes funny thing... complains about need co-processor, i tried some emulators without luck, and i never installed a 287 to test... i will buy jeje
ok, with this and emu386 load fine!! even with sound jaja little slow but playable, here im emulating a 386 and a 287 ... too much i think jaja
The attachment 1.jpg is no longer available
The attachment 2.jpg is no longer available
The attachment 3.jpg is no longer available
Highway Fighter and Swords of Xeen work on 286
I dont find Tiahuanaco anywere
Jo22 wrote on 2025-08-26, 08:36:
Hi there! The Japanese font utility Dos-J Plus uses 80386 real-mode instructions and works with emu386. Of course, there are lik […]
_
Thanks, yes i started with games, but some software work fine if not try to detect 386
Reply 4 of 5, by Jo22
theelf wrote on 2025-08-26, 09:35:
Hi, maybe another co-processor emulator will do?
Personally, I've tried quite a few 8087 emulators on one of my FPU-less 80286 PCs.
In the end, merely one had worked as intended (worked with AutoSketch 8087 version).
I'll have a look which one it was and then I'll write back.
PS: There are two kinds of FPU emulators (TSRs), as far as I know.
One will emulate the x87 instructions on 80286 and higher and will use INT7 (EMU386 uses INT6),
which works as a software substitute to a real 8087.
The second type will patch the software interrupts so that certain FPU-enabled applications can use it.
This special kind of FPU "emulator" will run on 8088/8086 and NEC V20/V30 processors, which normally can't do FPU emulation.
Edit: I *think* it's EM87 v1.3 (no 286 at hand yet), but to make sure I'll attach the whole set I had collected. Except Franke.387, which needs 386.
They're Public Domain/Shareware/Freeware, no commercial versions.
Edit: Ah, I see. You already got FPU emulation working, I've somehow missed the upper part in 2.jpg picture. My bad.
Edit: There might be some more Chinese DOS games that need 286/386.
Some are shown here.
Reply 5 of 5, by theelf
Hi guys, this is not related to emu386, because is not need, but im surprised Dreamweb works fine in my 286!!! despite in box, readme and manual of the game they say need 386+ the game run perfect in my 286
I decide to write this, because i did not find anyone in internet that tested in a 286 and write about this
Is just a problematic game, need 3mb ems and 596+ convenctional.. ouch.. not very 286 friendly
